Please help to get home:(
Discussion in 'Freightliner Forum' started by Shad, Sep 5, 2020.
  1. Shad
    Shad Bobtail Member
    32
    42
    Dec 3, 2017
    Hi folks,
    Today two engine lights, stop eng and def blinking pops up on my Cascadia 2017 390k mi. Truck derated to 5mph. Stopped at the rest area. All dealerships are closed till Tuesday. Also i got SPN 520372/16 fmi 14. I am 250 mi away from home. I stuck somewhere between Detroit and Lansing MI.
    Tried regen twice, nothing
    Tried reset codes shutting power for 15min and codes are still there and I cannot move.
    Anyone know how to bypass deration of engine and get home. Yes i know that need to tow it to stealership but everything is closed until Tuesday. Please, any ideas? And yes researched a lot but no clue what’s the problem is. Everything could be def pump, def crystalized, def dozer, nox, scr. But main point is can i reset anyhow stop eng light to continue to drive?
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Try to unplug speed sensor it's located on the transmissions tail shaft, good luck
    Matt1924 Thanks this.
  4. blairandgretchen
    13,210
    70,197
    Dec 9, 2011
    South west Missouri
    Tried removing battery cables for 15 minutes?
    Sounds like a tow is imminent.
    Matt1924 and 25(2)+2 Thank this.
  5. Shad
    Shad Bobtail Member
    32
    42
    Dec 3, 2017
    I saw video on youtube but it is for manual transmission only it says. Anyone tried with automated trans?
  6. blairandgretchen
    13,210
    70,197
    Dec 9, 2011
    South west Missouri
  7. Shad
    Shad Bobtail Member
    32
    42
    Dec 3, 2017
    I shut the switch. But not batteries
  8. D.Tibbitt
    140,663
    SPN 520372 / FMI 16 - SCR closed loop at maximum limit fault.
    everything im reading online says it just needs a system update . Or it could be a bad scr all together.
    I dont think u are going to be able to clear it without the detroit software
  9. Shad
    Shad Bobtail Member
    32
    42
    Dec 3, 2017
    The funny thing that 2 days ago it happens first time and dealership at Indianapolis diagnosed this and updated also did 4 hour scr test. This happens again today. Whatta shame:(
  10. Shad
    Shad Bobtail Member
    32
    42
    Dec 3, 2017
    Well, i guess i stuck here for good. I feel freaking sad fellas. But thanks for yall for responding that quick. Have a wonderful wknds.
  11. D.Tibbitt
    140,663
    Can u get a uber to a hotel
    Matt1924 and blairandgretchen Thank this.
