Please help me find a non-VGT direct bolt turbo?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dedicated lanes, Mar 16, 2023.
  1. dedicated lanes
    dedicated lanes Bobtail Member
    Mar 16, 2023
    Indianapolis
    recently had a turbo go bad, due to a head gasket that had went bad prior. Anyways, I’m looking for a non-VGT direct bolt turbo. Similar to the 12.7 turbo swap. But will bolt right in place of my 2006 14L 60 series manifold. Do they make an animal? I already have an ECU programmed for this. I know ill have other stuff I Have to do. I plan on deleting egg/cooler. ECU its been deleted etc.
    Thank you,
  3. Space Truckin
    Space Truckin Light Load Member
    108
    216
    Mar 8, 2023
    Venus, Mars, and Tampa, FL
    A more descriptive thread title might garner more relevant attention.
  4. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    171702 is the turbo. you want.
  5. bjytech
    bjytech Light Load Member
    229
    207
    Nov 9, 2013
    This is the turbo most switch to on the 14L, but it does require changing the exhaust manifold. I don't know of any options other than the VGT that bolt to the VGT manifold flange.
  6. rollin coal
    rollin coal Road Train Member
    13,078
    25,829
    Mar 29, 2008
    TN
    That 171702 is a good turbo that's what I had on my 14L DD. It's cheap too. I think you can still get them for about $800. Be careful not to surge it :)
  7. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    it does not require to change manifold. or oil drain
