PLEASE HELP!!! Do I need to replace batteries
Discussion in 'Trucks [ Eighteen Wheelers ]' started by missjhawk, Aug 10, 2017.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I have a 16 freightliner
    I went out of town for a funeral I forgot to turn off my kill switch 3 days later when I rerun truck was completely dead my built in fridge was on I unplugged everything else it took 20 min for truck to turn over with a jumper box, jump cables hooked to a pick up, and a shop charger all connected to my truck NOW my truck drags when I start it just turning it off to get fuel my volts be at 13.7/13.8 when I drive lights on/off or idle it is 13.9-14.1 my question is did I ruin my batteries when it went dead what do I need to start replacing the tech did say one of my cables was loose not sure if he tightened it he did get his box out not really sure what to do
  3. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Well,it takes AWHILE to charge up them 4 Dead batteries,this has been my experience 20 minutes isnt unheard of.13.7 to 14.1 is normal also.With battery cable tightened up? I would suspect your Starter/solenoid needs replaced.Have someone tap on the starter case (while you start it) see if it still drags.Its a 2016? Do you turn it on and off multiple times everyday?
  4. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    No the only time I turn it off is when I get fuel every day today was the worse but I remember when I went home wed I nosed in my driveway it dips in I had hit key couple times I thought I wasn't on clutch good enough I usually back in
  5. brian991219
    brian991219 Road Train Member
    2,921
    5,811
    Aug 10, 2013
    Lords Valley, PA
    How long ago did you run the batteries dead? If it was only an hour or so then they may not be fully charged yet which will give you slow cranking. Your voltage is fine, so your alternator is working.
    Check the loose cable, if they didn't fix that you will have cranking issues as well. If neither of the above applies then you may have damaged at least one battery by deeply discharging them. Typical truck batteries are simple starting batteries and not designed to be fully discharged. If this is the case you can have each battery tested, it is a simple procedure but can be time consuming to do correctly. Each battery will need to be charged and tested individually. Now, if you find one bad it is a best practice to replace all batteries at the same time, usually if one is bad the others have been strained trying to keep up, plus the battery bank works better when they are of similar age and condition.
    Grubby and BUMBACLADWAR Thank this.
  6. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    You say its a 2016? Not really a lot of off on cycles for a starters life,but who knows.Just have to do the old process of elimination.Get the batteries load tested,check wiring to starter and solenoid etc.Good luck to you.
  7. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    Unhook all your batteries and test each of them individually. You may have one that has a dead cell now which will cause start voltage issues and pull down the pack when sitting.
    The bad battery will show a significant lower voltage than the others ... 3 to 4 volts different usually
    Jazz1 and Lepton1 Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    4 dead batteries it's a drain on them. Your numbers are ok, for maintaining a computer network on your truck. But they will never be the same.
    I will work on replacing the 4. You have winter coming and that already by itself induces additional stresses against your batteries.
    If you are in a position to get a APU truck that has one job, feed batteries, keep engin eblock warm, and circulate main fuel returns etc As well as provide hotel support to humans, air and heating. You really need to bite the bullet and get one.
    roshea Thanks this.
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Get a voltmeter , test all 4 and post the results.
    Lepton1 and x1Heavy Thank this.
  10. dryside
    dryside Light Load Member
    78
    31
    Oct 16, 2016
  11. dryside
    78
    31
    Oct 16, 2016
    one bad battery can pull the others down. if the batteries are more than 4 yrs old it would be a good idea to replace them all. If they aren't marked it is poor maintenance practice and i would probly replace. Could be your connections check for white corrosive powder clean w/ wire brush . severe use on batteries in a modern truck, relatively cheap to replace batteries , much less than roar service.
    x1Heavy Thanks this.
