Hopefully somebody here can help me:
1998 cat 1lw 3406e in freightliner classic
No start
Ecm will not power up
power supply and grounds have been verfied and load tested (keyed hot, constant hot, and ground)
Ecm has been bench tested and ran on boyd caterpillar dyno in corbin ky and is good
Check engine and engine stop lights do not come on on dash but i have confirmed that they do work (bulbs not bad and wires are good)
What am i missing???
Im trying to figure out if anything else in the truck can cause this? J1939? Datalink?
Please help! Cat 3406e not powering up or communicating with truck
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2tonchevy, Sep 6, 2022.
If you have power in to the ECM (and good ground) at the connector then I would say it's the ECM. Try a spare and see what you get.
Thanks!
Tried a good spare ecm, no power up. and had this one tested at CAT on their dyno. Its good. -
Have you manually put 12v and ground directly to the ECM from the batteries?
If all of this actually checks out, and I didn’t have a CEL come on on two different ecms, when key is turned on, I would have to suspect the OEM harness or plug. Terminal pin bent or some such. It’s wasn’t mentioned whether this happened suddenly on a good performing truck or is this a resurrection of some fashion. Everything you have described having been checked has been on the engine harness side except the key on power. In other words if all checks good as you say and you have no CEL illuminating I would have to suspect, once again the OEM side.
Another thing. If this was brought to me in a no start condition as this, first thing I would do would be connect a Pro Link or similar and see if the ECM was in fact communicating via the J1939, and whether I was receiving any outputs from the ECM. When the CEL comes on at start up, the ECM is saying, hello I’m awake and ready.Last edited: Sep 6, 2022
was the truck running as a daily driver? im thinking wire harness as an offhand guess by what we have so far.
As stated: ive confirmed and load tested the ecm supply hots and the ground. And ive confirmed tgat the CEL does work when grounded manually through the harness.
Idk what else to check?? -
I will connect my laptop to it and see what happens
Question: if the laptop wont connect to the ecm...how do i troubleshoot the j1939...and is that the same thing as " datalink"?.
The guys at CAT said that not having datalink connectivity (5v) wouod keep the ecm from turning on??
I cant find anyone that can explain to me what will keep the ecm from turning on other than pin 4 ,5 and 6. And no one has been able to tell me how to trouble shoot the "datalink" ...what it is, or how it works. -
Yes the 1939 is the data link that transmits information (bytes), between devices, components,sensors and whatnot. You would do well if you haven’t already, is to google 98 Freightliner basic wiring diagram, print it off and use it as a guide. There are things that could cause an issue with data transmission, opens, shorts, short to voltage, as was mentioned bent or pushed back pins to name a few. At the time and I would imagine now as well Ftl wiring harnesses were without a doubt one of the best, using good terminals and pin designs with all connections soldered. We found very very few issues with a harness problem that was not caused by being worn, cut or broken. Get a good DVOM and get after it. Good luck.
Bean Jr. Thanks this. -
you should not try to ohm a wire harness or any other wire for continuity. a tiny strand will ohm out to 0. you need to load test each and every wire from connector to connector. it aint fun.
