Please help! 2020 cascadia
Discussion in 'Freightliner Forum' started by Sixela918, Apr 28, 2023.
  1. Sixela918
    Sixela918 Light Load Member
    256
    395
    Nov 24, 2021
    Phoenix, AZ
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Did you resolve the problem? I am wondering if chaffing of wires on your Power train controller area network (PT-CAN) would be causing that. I would think that electrical harness that feeds the powers , grounds and CAN lines to transmission might be chaffing. I would be looking along left side of transmission for chaffing and also around the harness brackets between the fuel module in front of or near air compressor. I have found a mirror with a telescoping handle is helpful with inspecting where the harness wraps around the top at the left of transmission. Curious if you were getting CAN communication faults.
    QUALITYTRUCK Thanks this.
  4. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    Freightliner has it now. I'll update here with their finding.
    austinmike Thanks this.
  5. Sixela918
    256
    395
    Nov 24, 2021
    Phoenix, AZ
    According to freightliner the issue was a bad pt-can harness. Oh yeah $1700 labor, $113 parts :eek::eek::eek:
    RocketyMan, austinmike and SWM_TECH Thank this.
  6. SWM_TECH
    139
    145
    Apr 15, 2018
    Thanks for the update. Great to hear you got the problem solved.
    RocketyMan Thanks this.
