Places to Park in Chicago West Loop???
Discussion in 'Truck Stops' started by DsquareD, Jan 18, 2014.
  1. DsquareD
    DsquareD Road Train Member
    1,439
    857
    May 21, 2009
    Green Bay, WI
    Where are some good places to park for a 30 minute break in Chicago's west loop? For instance, if I want to go to Graziano's at 901 W Randolph street is there a place where I can park the truck to run in and get a sandwich?
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Chicago isn't really truck friendly. Three blocks north of there is a gravel lot trucks hang out to deliver to the market. You might catch a roach coach in the market area around breakfast and lunch.
    Other than that it's either an Oasis, back up to the WI line, Monee, Gary and Minooka for the truck stops.
    I'm sure you could get food delivered if you wanted some Chicago cuisine.
    Isn't Grazianno's on a one way south? If it is go one block west and three blocks north will run you into that lot. Once you get to the lot it's one block east and 1/2 block north to the entrance.. That turn eastbound in front of the lot is tight and narrow but take it wide and it's no problem.
    That's about the best I can do is give you a place to park. There are cafe's in the area if you want to walk from that lot. I usually didn't hang around.
    DsquareD Thanks this.
  4. Minia
    Minia Light Load Member
    69
    28
    Nov 8, 2013
    Chicago
    you can try Fulton St. (2nd str. north of Randolph). on weekends not much going on there, you should be ok for 30min.
  5. DsquareD
    1,439
    857
    May 21, 2009
    Green Bay, WI
    I know Chicago isn't truck friendly, but they have some fantastic places to eat.
    As far as the oasis stops go, they are mostly limited to the fast good chains. Also, with the new 30 minute rule I'm noticing that it is getting more difficult to get a spot. I used to pull in to the Lake Forest oasis, run in, use the facilities, get a Polish sausage and hit the road in about 15 minutes or less. Now I frequently pass it by without a second thought because it is usually full.
  6. 25(2)+2
    18,749
    45,387
    Sep 18, 2006
    the road less travelled
    Downtown, north of Fulton Market is a lot where a company parks their trucks and and trucks delivering are allowed to park there, but they shut the gates from afternoon until about 10 PM when they come in to fuel the trucks. E-logs won't let you move at all during the 30 minutes? There are places here and there, but that area is high traffic. You can't block someone that wants to leave, you can't park just anywhere, and since they are turning the old Fulton Cold Storage building into an office complex, the parking that was there around that building is barricaded off.
    The roach coaches are good for that area. There are places out a little ways, but not in walking distance, I park at a place off Pulaski south of 55, and there are other places to rest in that area where you don't get pestered during a long break.
    There are other places where you will be pestered pretty much anytime of the day, unless a cruiser is parked nearby.
    On edit, north along US 41 is the Full Moon Cafe, open 24 hours with truck parking, easy access northbound, possible southbound with a little backtracking. Greek influence on the food, and it was pretty good.
  7. DsquareD
    1,439
    857
    May 21, 2009
    Green Bay, WI
    This is a spot I will definitely check out. I just looked at it in satellite view in iPhone maps and it looks like it has promise.
  8. IH Truck Guy
    4,119
    46,696
    Mar 2, 2008
    Purgatory
    Just double park and tell the cops your making a delivery...:biggrin_25523:
  9. DsquareD
    1,439
    857
    May 21, 2009
    Green Bay, WI
    I have one spot in front of a fire hydrant that is heavily marked, but also well used. One time as I was getting out of the truck I saw the parking utility pull up behind me. I went back to see if he was going to ticket me and he said, "depends on how long you're planning on staying." I told him I was just getting a sandwich and he said that would be ok.
  10. LakeErieHillbilly
    LakeErieHillbilly Light Load Member
    74
    18
    Feb 5, 2012
    Northern Ohio
    Not sure how far west your talking but off route 80, exit 130 is South Larkin Ave. Right there (going north) is an old empty Wal-mart parking lot where trucks park. In a quick walking distance is a Steak and Shake, Wendys and Taco Bell. Sams Club is right beside it. If you turn left on route 52 a new Wal-mart is there and close to that is a Golden Corral.
  11. LakeErieHillbilly
    74
    18
    Feb 5, 2012
    Northern Ohio
    Oh yeah, this is in Joliet ILL and is located between route 55 and 355
