Placarding question.
Discussion in 'Hazmat Trucking Forum' started by snowez, Sep 3, 2022.
  1. snowez
    snowez Light Load Member
    151
    141
    May 15, 2013
    Okay I need some help for real world placarding
    So column 3, column 6, and on the far right of the chart is placard advisory. Most all of these per UN number show the same placard but in column 6 some UN numbers show 2 different placards. Does this mean I need to put two different placards on each side of the trailer?
    Getting ready to start my first hazmat job and want to make sure I do it correctly. I guess what i’m trying to find out is what column is for placarding the outside of the truck.
    Is the placard number they give on the BOL the only number I need or should I be looking in the book to see if theirs more placards required then what was put in the BOL.
  3. Judge
    84,607
    Depends.
    If it’s flammable + UN just the flammable with UN.
    if it’s Environmental hazard too, need that one as well.
    or Corrosive + Flammable etc
    On a 4 compartment tank i once had 32 placards..
    baha Thanks this.
  4. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Depends, could you post a pic of the hazmat column of the BOL? I haul some hot pavement dressing with xylene mixed in. UN 3256 HOT but it's class 3 and 9 so I have to use class 9 3256 with class 3 flammable as well
    wis bang Thanks this.
  5. snowlauncher
    snowlauncher Road Train Member
    1,231
    2,602
    Mar 28, 2014
    Southeastern ID
    The reference chart in the hazmat book will tell you exactly what placards you need to run for each specific UN# and hazard class. When in doubt it's a good rule of thumb to run placards, even if it's not a placardable amount. As long as the hazmat class and the UN# matches what's printed on the BOL.
    For example if one hazmat class on the BOL requires placards + UN#, and another doesn't, it's ok to run placards for both types. The DOT won't pop you for over placarding, as long as the placarded classes match the paperwork.
    MACK E-6 and wis bang Thank this.
  6. wis bang
    wis bang Road Train Member
    3,348
    3,918
    Jan 12, 2011
    Levittown, PA
    Subsiderary hazards do require a 2nd placard. there are flammable liquids that are also inhalation hazards requiring the class 3 with UN number [tankwagon] and a class 2 inhalation hazard with skull and crossbones...Shipper needs to provide the correct product description onthe paperwork and the required placards, as needed.
  7. MACK E-6
    48,131
    219,684
    You need to be careful though. That’s not a good idea for class 7 because the only group of class 7 material, which would be yellow number III, that requires placards is also highway route controlled.
    snowlauncher and wis bang Thank this.
  8. mustang190
    mustang190 Road Train Member
    2,827
    6,064
    Jan 18, 2011
    Florida Panhandle
    What does the BOL say?
    The placards must match the BOL and the shipper must provide them.
    tscottme Thanks this.
  9. Dave_in_AZ
    370,533
    Post a pic of the bol.
