Pittsburgh Power Max Mileage
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Otr Traveler, Dec 17, 2023.
  1. Otr Traveler
    Otr Traveler Light Load Member
    84
    64
    Nov 19, 2020
    For those who use Pittsburgh Power Max Mileage additive in your diesel fuel tanks,have you had any success with it?? Any reduction in soot levels and/or increase in fuel mileage?? Came across this additive today and was curious if it actually works..
    Maurice
  3. Iamoverit
    Iamoverit Road Train Member
    1,530
    3,309
    Oct 31, 2023
    I would avoid anything PP like the plague if I were you. They're crooks and fraudsters.
  4. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    I've used it since it came out. I can't speak to the effect on a DPF or check engine lights because my truck doesn't even have a EGR. But I can say without a doubt it works. I changed a turbo 2 years ago, and I wiped off the soot on the propeller with a paper towel. And the soot had the texture similar to talcum powder. I imagine I would have had to use steel wool to get down to metal otherwise.
    I have a couple of old turbos in my shop, and I couldn't clean with a paper towel. But they'd been sitting there for 8 years or more, if that makes a difference. I can't say I noticed an increase in mpg, but there has to be if combustion is more complete-just hard to measure 0.1-0.2 mpg increase. I use Max Mileage in everything, and I've noticed a difference. I have a gas/oil mixture weedeater that would smoke bad under heavy load for a little while. And now, no more. I use it in a 1987 Dodge pickup with a carburetor, and it starts a little easier without cranking as much.
    runningman0661 Thanks this.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    They did so well with their part on that maga truck they helped build a long while ago……
  6. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    From everything I've read and hearing the experiences of people I know who use it it DOES work for keeping emissions systems clean including APU's and bunk heaters. Supposedly your troubles with soot build up and NOX sensors, etc. will go away.
    But I have not heard anyone say it increases mileage as the name would suggest.
  7. JB7
    JB7 Medium Load Member
    643
    895
    Dec 13, 2022
    Laurel, MD
    This from Howes. Howes also has a Fuel Savings Calculator on their website based on a 5% increase in economy. If one would get the 5% it more than pays for itself.
    Defender’s state-of-the-art IDX4 Detergent both cleans and prevents all deposits, including Internal Diesel Injector Deposits (IDID), from forming on your injectors. Additionally, this alcohol-free injector cleaner safely removes water, leaving only pure fuel to burn. Diesel Defender also guarantees a minimum 5% increase in your fuel economy.
    Oxbow Thanks this.
  8. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    Everyone has different opinions on additives, I for one only use Power Source Diesel Kleen. I purchase it by the case on eBay. I tried Howes and it didn’t do squat, Lucas is overrated and overpriced.
  9. MRMTRANS
    334
    372
    Apr 28, 2015
    Fuel mileage gains of 5% seem totally unrealistic. What I learned is diesel engines, when running properly, burn 98% of fuel. You can only get 2% more fuel burned, which is impossible I gathered.
  10. liner
    liner Medium Load Member
    469
    675
    Mar 15, 2008
    ontario
    Snake oil. Did absolutely nothing for my truck. Big waste of money.
