Pittsburgh Power Foam Cleaning
Discussion in 'Ask An Owner Operator' started by JonJon78, Oct 21, 2018.
  1. JonJon78
    JonJon78 Road Train Member
    7,042
    37,578
    Jul 1, 2018
    Just curious if any of you have had the Diesel Force Engine Maintenance and EGR Cleaning done by Pittsburgh Power? I believe I've seen somewhere that another company up in Michigan does something similar.
    Its supposed to flush out all the soot buildup on EGR, Intake, Engine Internals, Turbo, and Exhaust.
    Cost is $1625 plus you need oil change afterwards. Anyone who was watched Rawzes "EGR Tuneup" videos on YouTube this method seems similar without taking a bunch of stuff off the truck and doing it manually.
    Those of you who have had it done, how has your truck performed since? Below are pictures taken off Pittsburgh Powers website of before and after... Definitely appears to do a good job. 15401624723884027605125119137234.jpg 15401625060254758779101088255315.jpg
    4mer trucker and Shock Therapy Thank this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Rawze also notes when he has the intake manifold off someone's truck to not disturb the soot inside. The channel ways are large enough it doesn't make much difference. But if you chip some of the hardened soot off and it gets stuck under a valve you can have big problems.
    I will do it manually.
    JonJon78 and Shock Therapy Thank this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I had it done, also got the dorthy soot collector put on and an overhead done and the 600 tune. So far running good, I bought a 2015 680 with an ISX in January and took it there first thing and had it done so I can't give a comparison to what it's like beforehand.
    JonJon78 Thanks this.
  5. JonJon78
    7,042
    37,578
    Jul 1, 2018
    Is that dorothy filled up completely with soot every month? How much did that run?
  6. 2 CHAINS
    2 CHAINS Light Load Member
    241
    198
    Sep 8, 2018
    Some solevants arent good on plastic parts that you see on some sensors. Deteriate plastic .
