pipe stake questions
Discussion in 'Flatbed Trucking Forum' started by fastshadow, Apr 4, 2013.
  1. fastshadow
    fastshadow Light Load Member
    64
    24
    Feb 24, 2013
    What do you use for pipe stakes? Did you buy them or make them? If you bought them, where? How many do you carry? And last where do you secure and store them when you're not using them. Thanks for the help.
  3. deerslayer1543
    deerslayer1543 Light Load Member
    57
    10
    Jan 21, 2010
    topeka kansas
    id check with the manufacturer of your trailer to start.Always stored mine in the box between my spread.Ive actually seen guys use 2 x 4's but I wouldnt advise it
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I made mine. Length of channel iron with a piece of round stock welded to it so they don't slide clear through.
    I have 6 of them. I lay mine in the bottom of a tool box and cover them with a rug so they don't rub a hole in my tarps.
    SHC and aiwiron Thank this.
  5. botoler
    botoler Bobtail Member
    18
    9
    Sep 12, 2012
    i made mine out of square tubing. put 4 and a half inch on the trailer outside the rub rails and have 4 inch stakes to slide in them, covered with plastic corrugated tubing.
    TwinStickPeterbilt and MJ1657 Thank this.
  6. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    pipe steaks are they the same as tube steaks, called hot dogs or weiners?
    but seriously , do just as old mj described. they work great of put in a stake pocket upside down, orput em across the front of trailer in the pockets.
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I bought mine from a place in Odessa, TX for $100. They are 4' tall when in the pockets, and 2 are rectangular tubing and the other 2 are channel tubing. They are like that so u can run hook a chain to the channel, run it around the square and hook the binder to the other lip on the channel. I carry mine inside my enclosed headache rack. Most flatbed guys I see carry them in a box or flipped over and thru the pockets on the trailer.
    fastshadow, MJ1657 and botoler Thank this.
  8. fastshadow
    64
    24
    Feb 24, 2013
    Where in Odessa TX if you can remember? Do you find that you ever need more than 4 or is that pretty much standard?
  9. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I only ever needed the 4 and that seems to be the standard. Only time I can see you needing more would be if you hauled say 2 sets of 20' pipe, but for most everything u will only need the 4.
    The place is just south of the Loves in Odessa, turn right on Birchfield St. and it runs right into their yard. I can't remember the name of the place tho but here's a pic
  10. Clasix1055
    Clasix1055 Even when I'm wrong I'm right
    998
    708
    Jan 26, 2012
    Toledo, Ohio
    You ever get to Toledo, OH, I will give you 4 that fit in the pocket...I purchases them for a load and used them once and I have no use for them now.... PM Me if you get here
  11. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    If you can't do what botoler did and weld large square tubing to the rails and large tubing stakes then make you own by welding two pieces 1 1/2'' square tubing together to fit in your existing pockets. This is much stronger than 3 1/2'' channel iron.
    botoler Thanks this.
