Pipe racks/pins?
Discussion in 'Flatbed Trucking Forum' started by dk2012, Jan 16, 2012.
  1. dk2012
    dk2012 Bobtail Member
    15
    5
    Nov 16, 2011
    Western Pa.
    Have an opportunity (pretty lucrative)hauling pipe dedicated, my question concerns "pipe racks/pins" that fit into the side pockets of the trailer 4 ft high aprox 4 of them, Does anyone know where I can get them? either fabricated , or used? I am in western pa eastern Ohio area Thanks in advance.Dave.
  3. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    Get steel channel or pipe and beat one end until it fits into your stake poc.kets...thats all they are.
    American Trucker
  4. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Is that how Lone Star does it?
    Because that's not how it's done.
    7122894003481 Thanks this.
  5. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    Hope you have a old steel trailer. Hauling pipe all the time with all alum trailer the rub rails will be junk in less than a year.
    As for the stakes you can make them your self. I bout #### when a driver in Huston told me he gave $125.00 for four at a trailer stealership. I have less then 40 bucks in mine, that I dont use anymore.
  6. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Are you pulling your own trailer? If so invest in the permanent bunks that alot of pipe haulers have. Just sticking a pipe in a stake pocket really isnt the right way to go about it.
  7. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    For square pockets make them out of channel steel. Weld a stopper on them to the point of stopping them from falling thru.
    I would always use 6 of them, 3 each side just in case one bent or got lost etc.
  8. Mr Dave
    Mr Dave Light Load Member
    65
    48
    Jan 2, 2011
    Oklahoma City, Ok
    To save your trailer, always chain the pipe stakes together, it can save the side and rubrail on your trailer
    TheHealthyDriver Thanks this.
  9. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    its how us steel in lorain ,oh does it at their seamless pipe plant, they stick in pipe presses on one end and the band it at bottom and then band it each layer up
  10. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I use 4 made out of channel with a stopper welded to them and treated 2x4 bolted to the inside of them to make them "insulated" so they dont rub against the pipe (when shippers call for it) and then chain them together and tighten with binder. I have seen tons of dedicated trucks in Texas that has a removable stake system (no chain/binder needed) and fits into a steel (on their aluminum trailer) bracket that is permantley mounted to their trailer. I think it would be wise to do some internet checking in that area or just go to a machine shop like I did for mine.
    Big John Thanks this.
  11. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    I agree with Mr. Dave. We are not hauling pipe but poles. I just got finished building 16 bunks for our trailers and will be building some more to finish us out. I used 4x4X1/4" square tubing. They are 8' or 8'6" wide and 6' tall. Cut 45 degree angles but cut all pieces as if they are laying the same way. Do not make one cut and try to get two pieces. If you keep them all oriented the same...as if angle up...or angle down....the little vee that gets cut out is your gusset. We got 40' sticks but you could make them smaller for your liking. Like Mr. Dave said....we do not use our rub rails for stops. We bind them down. Our aluminum trailers just won't last using stops unless they are bolted to the side of the trailer. If they have any slack at all they will tear your rub rails up on aluminum. We also built them this way so the drivers would have an easier time laying them over. We backhaul hay alot and saving the drivers a little time and strain helps out. They simply take the bunk loose...lay it down...and rebind it. Then they are ready to load hay. Just some thoughts. We run about 16 flatbeds with varying loads....but normally poles. Let me know if you want to see pics of the bunks I built and how I cut them out...we had zero waste this way.
    Mommas_money_maker Thanks this.
