Peterbilt smart wheel
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mudflap77, Jun 29, 2020.
  1. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    Hey all,
    I am looking at upgrading to a Peterbilt 579 with their version of a smart wheel. Would switching to a custom aftermarket wheel be as simple as unplugging the connections and maybe removing the clock spring? Or would this cause problems with the multiplex?
  3. bad-luck
    bad-luck Road Train Member
    3,297
    6,061
    Nov 16, 2013
    Baltimore, Maryland
    I think it best to leave the stock steering wheel alone in the newer trucks, changing it is asking for trouble
  4. mudflap77
    864
    1,314
    Oct 11, 2010
    Ok do you have any reasons why? The steering wheel needs to be replaced either way.
  5. bad-luck
    3,297
    6,061
    Nov 16, 2013
    Baltimore, Maryland
    If you can get a steering wheel, with all the components that the stock steering wheel has, and it hooks up the same you may be ok. I just have found that sometimes aftermarket equipment just dosen't have the OEM quality. Some cases on certain equipment you are ok, others you are not
    Bean Jr. Thanks this.
  6. mudflap77
    864
    1,314
    Oct 11, 2010
    Thanks for the response. I think I need to clear up I wouldn't be hooking up any kind of smart wheel. I would be using just a standard SCI wheel. Basically eliminating the smart wheel functions.
  7. bad-luck
    3,297
    6,061
    Nov 16, 2013
    Baltimore, Maryland
    Ok. If you are eliminating the smart wheel functions. Think you will be ok
    mudflap77 Thanks this.
  8. pushbroom
    pushbroom Road Train Member
    1,779
    7,312
    Sep 1, 2012
    It will throw cab controller codes but no engine codes. Also you will lose all functions on there like cruise.
    Steering angle sensor for abs might need to get recalibrated
  9. mudflap77
    864
    1,314
    Oct 11, 2010
    Cruise can also be run off the dash switches can it not?
  10. pushbroom
    1,779
    7,312
    Sep 1, 2012
    If the cruise is in the smart wheel it wont have dash switches
  11. mudflap77
    864
    1,314
    Oct 11, 2010
    You can add the switches the plugs will be there.
