Need some advice and/or thoughts. I’m about to buy a new Peterbilt 389 to haul crude oil. Seems most of the trucks the dealers have in my area have low air leaf suspensions and are better optioned than air Trac suspension trucks. Any cons to using low air leaf truck to haul crude?
Peterbilt low air leaf
Discussion in 'Experienced Truckers' Advice' started by Rkw1969, Jun 12, 2019.
Page 1 of 4
Im running it on my truck hauling tankers where all of our company trucks run air trac. I get a better ride then they do. As far as any other difference's is I had to spec the TALL fifth wheel pedistals in order to get the height right. The air trac trucks frames are higher then the low air.
Lepton1 Thanks this. -
Yea that’s what my dealer said, just swap 5th wheel blocks. Thing is I’m not always on bad roads lol. Lots of black top. It’ll only be me driving it so it will be babied as much as I can lol
I had about 12" of ground clearance with an after market stainless steel bumper on a T2000. During the two and a half years I owned the truck with that setup I replaced that bumper twice. Once when driving at idle speed in 1st through muddy water and I suddenly dropped well over a foot into an unseen pothole (culvert?).
I've seen drivers out there with low ground clearance. It is a mistake. Many many mangled bumpers.Truckermania, JoeyJunk, Grubby and 1 other person Thank this. -
If your hauling over 80k air trac is the way to go, but air leaf rides sooooo smooth
adayrider Thanks this. -
Low air rides better, but doesn't handle rough roads near as well as air trac. that said neither is my choice for ride or toughness either one.
What’s your choice starmac?
Neway is my favorite, and what a lot of guy specs there trucks with up here.
Better ride, better traction, can't break it, but it is more expensive if you ever have to rebushing it.AModelCat, KB3MMX, rank and 1 other person Thank this. -
I’m stuck with what’s on dealer lots. All I’ve seen is low air and air track in my area. I had a truck spec’ed the way I wanted it and sh%# happened and don’t have time to wait in the build.
Itsbrokeagain and Lepton1 Thank this.
Page 1 of 4
