Peterbilt Kingpin Replacement cost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bbierce, Jun 6, 2016.
  1. Bbierce
    Bbierce Bobtail Member
    6
    Jun 6, 2016
    Can anyone tell me the amount roundabout labor cost for someone to replace my front axle kingpins in an 88 Pete 379?? Thanks
  3. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    As I recall, the last time I replaced the kingpins at a dealer it cost around $1,600. If you can find a dependable independent shop, you should do better. I did have kingpins replaced at a local shop and paid a lot less, but don't remember the cost.
  4. Bbierce
    6
    Jun 6, 2016
    okay thank you. I have a guy says he'll do it for 1000 labor cost. I already purchased pin kits.
  5. wore out
    wore out Numbered Classic
    15,319
    184,958
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Unless he is boring the axle and putting a sleeve in it, while the pins are out that's awful high in my opinion. They can usually be done in 6 to 8 hours depending on if you bought the kaiser no reams or the factory bushings that require reaming to fit.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    It usually takes 4-5 hrs. Book time is always high it seems. I think last set I did I charged about about 400 in labor.
    wore out Thanks this.
  7. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    Two shops in ft. Worth quoted $600, did it myself took a little over half a Saturday.
    EverLuc Thanks this.
  8. Bbierce
    6
    Jun 6, 2016
    Okay another question is....the spring bushings on front axle how much approximate for that to be done?? Thanks for all the advice..
  9. ClineER
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Your looking about another 4-5 hrs. And if you do mounts, pins and rear bushing (I rarely see front bushing in spring wore out) its around 5-600 in parts. So around a 1000 bill.
  10. AModelCat
    154,243
    Back when KW started using those junk rubber spring pin bushings on the steer axle a lot of guys converted back to the threaded greasable style pins. Independent shop I worked at we could swap out all 6 pins and bushings in about 4-5 hours. We got a lot of business because it took the dealer nearly twice as long.
  11. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Just did the rear hanger and the hanger and pins where around $100.00 from a spring shop on my Pete 359. Took me 2 hrs. but was on the passenger side. Could have been done in less time.
