Peterbilt frame replacement
Discussion in 'Peterbilt Forum' started by Loaderlou, Feb 17, 2022.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    130
    Feb 24, 2014
    Hi friends. Does anyone know of a shop in the northeast close to Long Island that can replace my double frame to a single frame on a 230” 379exhd to a 250” wheelbase. Thanks
  3. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    P.G. Adam’s in South Burlington Vt be the best place to start for frame rails. I don’t know if I’d want to pay a shop $100+/hr for all that nutting and bolting though. I re-railed an ‘85 Freightliner from aluminum to steel back in the ‘90s and even then I saved around $20k doing it myself. It’s a big job to start with, and it grows as you go. I didn’t change wheelbase. I only had to deal with hoses and fittings that were compromised somehow. You are, so think about every hose and wire that runs the length of the truck. Replace, or splice in a never ending headache? You get a truck apart to that point there’s no end of things you find that need attention.
  5. Ruthless
    Ruthless Road Train Member
    8,786
    85,961
    Aug 28, 2010
    The City.
    ETC Elizabeth Truck Center/CarCraft
    Prolly a wide variety of others at various prices as well right local to the island//
    I don’t know if he’d be willing, but you could ask TJ at Contraband Customs in Winchester New Hampshire.
    062 and Cat sdp Thank this.
  6. Loaderlou
    342
    130
    Feb 24, 2014
    Thanks guys. I wish I had a shop, I would love to tackle it myself. I know all the splicing and extending is going to be a job in itself but that’s why I’m looking for a professional shop to do the job. Not to mention all the drilling and painting and hardware ,etc. I have an ETC near me on Long Island. Gonna be pricey
  7. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    The thing about PG Adams is that you can send them your frame rails and they will redrill them exactly as they are drilled so when you get them back it's just assembly.
    I would imagine you can probably Mark the frame like say right in front of where the rear suspension would start and have them move that back however far that you wanted them to start the pattern over again to extend the frame and just have one long solid piece of frame without any cuts or splices. They probably can' even give a heavier single frame rather than having a double frame.
    Going from double frame to single is tough because I think most of the Peterbilts that double frame goes all the way up to the front axle. They can't just cut it behind the cab somewhere and splice into it. That becomes a much larger job.
    And those Peterbilt double frames always seem to swell and separate somewhere up front.
  8. Loaderlou
    342
    130
    Feb 24, 2014
    Hi Dino, that’s what I’m experiencing now. Although, I’ve done a lot of repairs and upgrades to the truck and the suspension shop I go to says the worst part is after the fifth wheel. They say otherwise the chassis is tight and goes down the road straight. I’ve had it painted and having a platinum kit done as we speak.I’d like to stretch it a little and add a bunk. I’m trying to keep the weight down so eliminating the inside rail should make up for the weight of the bunk, if not more.
    Dino soar Thanks this.
  9. Loaderlou
    342
    130
    Feb 24, 2014
    Hi Ruthless. I checked out Contraband on line and it looks like they do nice work. Are they pricey?
    Ruthless Thanks this.
  10. Ruthless
    8,786
    85,961
    Aug 28, 2010
    The City.
    you’d have to call and ask/ I think pricing is very fair, but I never had a truck re railed by anyone, so-
    blairandgretchen Thanks this.
  11. roundhouse
    roundhouse Road Train Member
    3,129
    7,023
    Jul 11, 2018
    Probabaly cheaper to sell it and buy a longer single frame rig .
    Sure be a lot less downtime .
