Peterbilt Dome Light Issue
Discussion in 'Peterbilt Forum' started by AFX, Jul 23, 2021.
  1. AFX
    AFX Bobtail Member
    17
    4
    Apr 17, 2016
    I have a 2007 Peterbilt 386 and the passenger side dome light above the passenger seat doesn't come one when the doors are open. However it does work when turned on manually. The driver side light, door lights, and lights under the dash come on just fine when the doors open, it's just the passenger side light. Anybody have any ideas on what it might be?
  3. Arctic_fox
    3,869
    19,554
    Sep 16, 2016
    Door sensor/toggle likely went bad.
  4. AFX
    AFX Bobtail Member
    17
    4
    Apr 17, 2016
    If the door toggle was bad, wouldn't no lights come on? Currently when either door is opened, the lights get triggered.
  5. RockinChair
    RockinChair Road Train Member
    4,930
    12,288
    Feb 19, 2012
    CC, TX
    I'll bet it's the computer that controls the lights - especially if this light comes on when the driver's door is opened.
  6. Arctic_fox
    3,869
    19,554
    Sep 16, 2016
    You would be suprised. Had one go bad in my ram 3500 and the wire stud to one light had corroded so no signal went through. Replaced the switch and it solved the problem.
