Hi, couple questions about them
2017 579 mx13.
Having lots of problems with them not working right. Can't imagine they are all going wacko.
1. Are all these the same? They all just open and close the blend doors so I assume they are.
2. I had problems with hot cold door. Pulled actuator. When I turn knob on control to say, cold, actuator turns in one direction. Stops a bit. Then turns again..
Then if I turn knob to hot , it turns but in same direction.
So since actuator has no circuit I it, I assume this means the control module is bad. Is this correct?
Thanks
peterbilt blend door actuators
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by markk, Feb 4, 2022.
