I replaced my dog bones from diff to frame 11 months ago. Looked original 600k on truck, bushings were cracked and some falling out. Air trac suspension dealer sold me some that measured about 25”. They’re pushing out again so I looked online to send salesman part number and they are showing a measurement of 22”. Everywhere I look air trac shows 22” lateral dog bones also fitting air leaf. The 25” are showing fitment for LOW air leaf. Wondering if anybody with air trac could measure and see if the dealers wrong or the rest of the internet. The original ones I pulled off measured 25” as well but I haven’t been able to get tire wear even for the year I’ve owned the truck. Reason behind this started with chasing vibrations
Peterbilt Air Trac torque arms
Discussion in 'Peterbilt Forum' started by TruckerTW, Jul 22, 2023.
The lengths have changed over the years so I can’t be much help. I have a ‘73 with AirLeaf and a ‘74 with Air Trac. Also Sometimes there was a difference between Rockwell and Eaton axle housing's, but they usually used shims on the mounts to make up difference in lengths.
If all else fails and you have access to a spring shop locally they should be able to press out the old bushings and press new ones in the old original rods. -
How could you even install the wrong length? 3" is a big difference. You have to be pushing or pulling the axles way out of line to even get them bolted up. Things would be way out of wack.
Oxbow and Diesel Dave Thank this. -
lester Thanks this.
The arms he’s talking about shouldn’t change pinion angle. They are the arms that control the side to side movement. With the wrong length you will have one axle on a tandem kicked out farther to the side then the other.
Measure between frame and inside tire on each axle. Put tape measure from outside of frame rail to side wall of tire. See how much different the gap is. That will tell you how far over each axle is kicked out. Should not be more than 1” difference from side to side on the older AirTracs. That is were proper length and shims between frame and frame mount for bar come in.TruckerTW Thanks this. -
You can also get an idea how far out the axles are kicked out when hooked to a 96” wide trailer. If perfectly straight look at each side and you will see that most of the time the sidewalls of tires on axles on one side will be just past the edge of a trailer and the other side my be flush or just inside the edge. Small detail I know but it is there. But having said that I have seen many trailers with kingpins installed off center, so if that is questionable that measurement needs to be confirmed as well.
