Peterbilt a/c help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ashman_42, Jul 6, 2013.
  1. Ashman_42
    Ashman_42 Light Load Member
    248
    64
    Aug 14, 2011
    I believe I have a issue with two of my petes a/c systems, I'm not too fluent with orfice tube/accumulator hvac systems. Both trucks compressors cycle off at 20psi on the low side and turn back on pretty quick after, the compressor will do this 3 times and then turn on and stay on till the high side builds to 250psi and turns on the engine fan to lower system psi. 1st truck is 07 367, has a new condenser, orfice tube and accumulator, 2nd truck is 07 378, has a new compressor, both charged to 2lb8oz as the decal on the firewall states, and both cycle the same as I described < which I don't think is normal, there should be more of a delay between compressor clutch on cycles. What tells the compressor clutch to re-engage after it hits it's 20 psi mark? Thanx
  3. j-dawg
    j-dawg Light Load Member
    164
    47
    Dec 21, 2011
    Oil town, Ab
    Give gearhead a shout. I'm sure he'll have an idea.
  4. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    the fan should kick on at 350 psi I believe, and 20 psi is extremely low...
  5. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    This is common with pete. Is the evaporator clean? If so try adding 1oz. of 134a at a time until the compressor runs right. The tag on the truck that tells you how much to put in is not always right on the petes for some reson. I was told this at pete's ac class I took in baltimore when they started using the orfice tube. Now they went back to expansion valve what's that tell you. Just add a little at a time there is a thin line between it working right and the system freezing up. While your adding watch and make sure your engine fan still cycles. Then turn fan speed for blower motor to 2 and make sure the compressor will cycle off at some point. The system cycles off of pressure because there is no freeze switch. So the system is very sensitive to proper charge. The system uses a pressure switch which is gray in color and located in the low side To cycle the compressor.
    Ashman_42 Thanks this.
  6. Ashman_42
    248
    64
    Aug 14, 2011
    Thanx gear head, makes sense, the longer I can keep that psi to 20psi on the low side the longer the clutch will stay disengaged, and by adding it should do that.
  7. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    I put 3# in an expansion valve 379.
  8. Manvan
    Manvan Bobtail Member
    14
    Can someone point the location on the expansion valve and orifice tuve on these 2007 Peterbilts 379 thank you
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    No expansion valve, orfice tube is located @ evaporator inlet.
  10. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Orifice tube is inside the evaporator high side tube. Accessed from the outside at the firewall. Disconnect the lower line from the evaporator and pull the tube out with needle nose and make sure you have a firm grasp. Pay attention to arrow direction of refrigerant flow. The cab does not have an expansion valve on orifice tube system.
    The bunk may have expansion valve and it is mounted inline at the evaporator inlet.
    Manvan and spsauerland Thank this.
