Peterbilt 579 Dry Weight
Discussion in 'Experienced Truckers' Advice' started by Youngtrucker19, Jul 24, 2015.
  1. Youngtrucker19
    Youngtrucker19 Light Load Member
    280
    23
    Feb 13, 2013
    Any drivers out there know what the dry what of a new 579 peterbilt is? I have looked every where and can't find it.
    Road Killer Thanks this.
  3. glitterglue
    glitterglue Light Load Member
    53
    45
    Jan 22, 2011
    Adair Village, OR
    From answers.com, I found this:
    What are the dimensions of a peterbilt 379 semi truck?
    I found that on a website selling a 379. BTW I'm not a trucker.
    DIMENSIONS
    GVW: 48,000 LB Front: 12,000 LB Rear: 36,000 LB
    W x H x L: 96" x 12' 10" x 29' 2"
    Wheelbase: 265"
    Cab to Axle: 83" from fairing 102" from sleeper (*Don't undestanding that..XD)
    Weight: Estimated: 18,000 LB
    ... 18k - 20k #'s depending on setup and fuel capacity would be my guess.
  4. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    You do realize that a 379 and 579 are not exactly the same right?
    To the OP,.. There are many different specs to correctly assess the curb weight of a 579.
    Many factors to consider.
    Wheel base
    Sleeper size or day cab?
    Engines,.. Paccar MX or Cummins?
    Fuel tank size
    Installed equipment?
    Guessing its anywhere from 17k to 20k? I know that doesnt help,.. but my guess is that it would be similar to a 386.
    Hurst
  5. glitterglue
    53
    45
    Jan 22, 2011
    Adair Village, OR
    LOL.. Typo, big time!
    /me hides head in shame!!
    HorseShoe Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    yep, depends on the spec of the truck.
    my 16 FL is heavier then the 12 FL i just got out of. Both are Cascadias.
    Longer wheelbase. Headache rack. Rack for tire chains. And 50 gallons more fuel in the tanks. And lastly. loadlocks on the sleeper.
  7. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    The truck will have an engineer's estimate of curb weight stamped in it. (from Pete) The only way to REALLY know is to have the deal run it over a scale; and not how much fuel is onboard. You can calculate from there. If you are serious about buying one a dealer will be happy to weigh it.
    Road Killer and MJ1657 Thank this.
  8. Youngtrucker19
    280
    23
    Feb 13, 2013
    Thanks for the help I knew about the stamp, but no matter how serious I get with dealers they never follow through.
  9. KenworthGuyNH
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Just go test drive it and ask to weigh it at the same time. On 389s the stamped weight is #### close; I imagine the 579s would be too.
