Peterbilt 379
Discussion in 'Ask An Owner Operator' started by truckmetal13, Apr 23, 2009.
  1. truckmetal13
    truckmetal13 Light Load Member
    101
    4
    Jan 8, 2009
    Chicago, il
    Can you tell me a fuel economy on PETERBILT 379
    thanks
  3. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    The fuel mileage depends on a lot of factors. Lets start with what kind of trailer your pulling, weight, where ya gonna run mostly, size of motor (maker and hp/tq), transmission, rear gears, tire size,what mph you like to run at, if theres any air deflector on the truck,and flat top sleeper or ultra-sleeper just to name a few.
    Ya can't just say that a 379 Pete will get 5mpg cause there are way to manyy things to consider.
    1989 Pete and truckmetal13 Thank this.
  4. truckmetal13
    101
    4
    Jan 8, 2009
    Chicago, il
    Quantity 1 Stock Number
    Year 2004 Manufacturer PETERBILT Model 379EXHD Price
    Location
    Condition USED Sleeper Size 63" Sleeper Unibilt Engine Specs Cummins Engine Type ISX Horsepower 450 Mileage 566,523 Transmission 10 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Flex Air Ratio 3.55 Tires 455/55/22.5 Wheels All Aluminum Wheelbase 250" Number of Rear Axles Tandem Front Axle Lbs 12,000 Rear Axle Lbs 40,000
  5. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    With a loaded reefer or drybox near gross - 5.5 to 6
    Light, or with a flat - 6 to 6.5
    truckmetal13 Thanks this.
  6. bubba mark
    bubba mark Medium Load Member
    615
    733
    Apr 9, 2009
    That's almost identical to mine. I get between 5.7 and 6.2. I pull a dry van. Loads weight between 15,000 to 30,000.
  7. TripleSix
    127,950
    Personally, I would go with a 475-500 HP truck. 450 is decent for a flatlander, but if youre planning to run 48, the extra power will save you fuel and perform better. Cant see paying for a truck that will lose to a Swift truck in a pulling contest.
    Working Class Patriot Thanks this.
  8. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
    From my own humble experience..... 525 or better HP; and an 18 speed for those who prefer not to watch the grass grow on the 70 climbing up through Vail...
    RAG Thanks this.
  9. TripleSix
    127,950
    No argument from me. He can get by with a 13 as long as its rated for 1800 ft lbs.
  10. 1989 Pete
    1989 Pete "Pine Tree Eater"
    Need more info driva??? Cmon now
