I have a 379 that will not stay even. We have tried to change everything. Hoses, splitter valves, tank vents, and pickup tubes In the tanks. It still seems to suck out of one tank for the most part. So I am curious on peoples opinions on putting a tank selector valve in the system so it would only suck and return to one tank at a time. Just looking for some feed back on the idea. Thanks
Peterbilt 379 fuel tanks not staying level
Discussion in 'Peterbilt Forum' started by mudball66, Mar 3, 2022.
If you've replaced everything first make sure all your return hoses are the same length and routed so they are all at the same height. And difference if restriction will cause it to return to one side. If everything is right I'd just put #### off valves on the returns and whichever one is returning more just close the valve down half way or so. Play with it till you get them returning even
2022 389 got the same issues as I had in older 379’s. I think they just are not right and Paccar engineering don’t care. Add more useless crap but don’t improve on basics…
Badmon Thanks this.
