Peterbilt 379 daycab to sleeper conevrsion
Discussion in 'Ask An Owner Operator' started by Ridingsxrs, Jan 22, 2016.
  1. Ridingsxrs
    Ridingsxrs Light Load Member
    94
    21
    Nov 12, 2012
    Everywhere and anywhere
    Looking at converting a Peterbilt 379 exhd from a daycab into a sleeper.... Has anyone done this or is it even possible?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    If you have enough wheelbase it is possible. I have never done that just took them off. Is it cost effective? Probably better to buy a different truck.
    Well lets thank out of the box and back up a few years. Clarence had a 4000 White butterfly hood with an add on dungeon sleeper, 24 inches I thank. It probably would not have been so bad but he had not cut out the cab to match the sleeper opening. It was near the fuel island and I heard an odd sound and asked about it. No that's just Clearance. He is hung up here for the weekend and just walked back from the bar, feel through the window into the dungeon, he will be fine.
    Joe told me he saw a F model Mack day cab sleeper at a fuel stop in OK. When he came in the cab was up and the guy was wrenching on it. He said the sleeper was made out of plywood, square box mounted on the frame but the paint matched. Let the cab down, put a large tire tube between the cab and sleeper, inflated it and drove away.
    Just food for thought but I would go with plan A, buy up.
    Ruthless Thanks this.
  4. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    Will it be a uniblilt? How big of a sleeper do you want to add? The Pete cabs all look the same, but the internal structure isn't the same between a day cab and a unibilt sleeper cab. The windshield frame which Pete calls the mask is aluminum in a day cab, but steel in a unibilt cab. The brace over the doors that goes down to the floor is a lot stronger in the unibilt cab as well to support the weight of the sleeper. You might get by with adding a 36" bunk since they're not as heavy.
  5. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    I was at the steam show in Mt. Pleasant Iowa 9 years ago and saw a pickup slide in on a Freightliner classic if I recall correctly. Any thing is possible
  6. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    The unibilt comes in two can models. Ultra cab and flat top. The unltra cab is taller and the sleeper hole is taller. If the truck was once a sleeper and made a daycab than the job won't be that bad. If it's factory day cab don't thinks it's worth the time and money to do the job.
    Bean Jr. Thanks this.
  7. 1johnb
    542
    405
    Jun 13, 2012
    New Paris Ohio
  8. flat top
    flat top Bobtail Member
    44
    25
    Jan 28, 2010
    Colby Ks
    It can be done. Knew a guy once that turned a short hood day cab into a long hood flat top. Moved the cab back 8" I believe to make the long hood work. He also had left the factory day cab air ride on to help support the added weight of the 63" sleeper.
  9. Ridingsxrs
    94
    21
    Nov 12, 2012
    Thanks for the replies seems like I'm just going to sell the daycab and look for a sleeper. It is factory ultra cab. It never had a sleeper
  10. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    On the upside nice day cabs always fetch good coin. You may come out with a similar sleeper truck with a little cash left over.
    Ridingsxrs, Bean Jr. and BoxCarKidd Thank this.
  11. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    Bump.
    Anyone else running a day cab Peter with a unibilt 36"?
