Peterbilt 378: pros and cons
Discussion in 'Experienced Truckers' Advice' started by leadfoot80, Aug 3, 2013.
  1. leadfoot80
    leadfoot80 Light Load Member
    199
    34
    Feb 17, 2012
    S.E. WY
    Hey all, found out my new truck is a 2007 Peterbilt 378. I should be getting it next weekend but I was curious to see if anyone has had any experience with one. Good experiences, bad experiences, etc. From what I can tell, it's essentially the same as a 379, except the cab sits a few inches higher, and it likely has a fiberglass hood. I'd appreciate anything y'all can tell me about these trucks..
    Leadfoot
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,949
    Jan 18, 2011
    Hood is typically shorter--since it is not available in a long hood version--it is fiberglass(assuming original hood)there are aftermarket metal hoods available)and like u said sits higher--only about 4"higher on rails I believe-can be a set back or set forward afront axle depending on oriignal spec--essential was built as an easier to get around 379--for those who wanted the manueverablitiy-BUT didn't like the hood and headlit setup on the 377
    -other than that--it is pretty much same s a 379 from windshield back
  4. coastie
    coastie Road Train Member
    One thing to think about it. Fuel cost. In most cases you will only be getting 5.5MPG were a better aerodynamic will get better fuel milage. 378 nice looking truck but need to think cost of running it
  5. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    I used to have an 04 model 378. I liked it. The looks of a 379 but less hood which I prefer.
    Just a little info. If you keep your speed at 60mph or less there is little difference in fuel mileage in a hood verses an aero truck. I had an 04 378 and an 04 387. Both trucks had the same specs. Less than 1/10th of 1mpg difference. This was running mostly 2 lane with curves and some hills and mountains and some 4 lane with speed limits of 65 to 70. All loads were 75000 to 8000#.
    From your post it sounds like you are a company driver so you aren't buying the fuel anyway.:biggrin_255:
  6. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    Nope, not buying the fuel!
    We typically run a couple hundred miles of interstate in the Rockies and 30 miles (give or take) of dirt roads a day. My current truck is turned up to 80--I typically run 75+-.
    Are there any known issues that y'all know of that I need to watch for with a 378?
    Leadfoot
  7. fisher guy
    fisher guy Road Train Member
    1,993
    1,058
    Mar 22, 2009
    Ocala Florida
    if shes got a cat watch out of them actuators code 93 on dash my old acert cat hated them things aside from that good trucks i drive a 379 same thing only thing is u got the baby hood
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Thats total bull...the 387 is a bad example of an aero truck. Its also probably has a different rear end and is to heavy in the front. A true aero truck, like a fl Columbia will get a full mpg better then a 379 or 8 at 55 mph. As you go faster the difference is even more.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Wow, if was your boss and read that you would be fired so fast.
    You know your tires are only rated for 75. Going any faster is just asking for a blow out, and at those speeds, a crash. If you have off road spec tires and not highway spec, they are only rated to 65 or 70.
  10. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    what does he care, he drives a company truck set to 80 mph......
  11. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    It does have a Cat in it.. Not sure which one though. What do you mean by the actuators? What do I need to be watching for?
    I was not aware the tires are only rated for 75 mph.. How do you tell? And how do some of these owner/ops run at 80/90+ mph if that's the case?
    As for the speed, the truck was governed at 68 until it was brought to me. Speed limits are 75 here, so they had me take it in and get it set to 80. Their choice, their decision.
    If tires are truly rated at 75 mph, then yes, I do care. I had never heard that before.
    Leadfoot
