"Peterbilt 348 w/paccar px-9 (2021)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ntorres041788, Dec 8, 2022.
  1. ntorres041788
    ntorres041788 Bobtail Member
    9
    5
    Dec 8, 2022
    Sun Valley, CA 91352
    I have a Peterbilt with a px-9 engine which is what im assuming just the same as a L9 cummins with code
    spn 3521 fmi 18. im sure it is pointing out to be an issue with the def system. i have tested the def with a refractometer and it shows it is fine and did do a change in the def filter as well. has anybody else have an issue similar that can be of some help. i cleared the code but noticed it has returned..
  3. bjytech
    bjytech Light Load Member
    229
    207
    Nov 9, 2013
    The quality sensor is part of the smart unit (tank level, temp, and quality) so generally it is either a DEF quality issue or the sensor is bad, which is common. they were on national backorder last I checked on one but its been a while, hopefully supply has gotten better.
  4. ntorres041788
    9
    5
    Dec 8, 2022
    I was scared it would be that as i have already changed one in the past with our other trucks and they do not run cheap at all. considering it is such an extremely expensive part. i would of thought they would atleast fix the issue if its so common a part that goes bad..considering the costs..
  5. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    How do you like the PX9 other then the DEF issues? Thinking about a Peterbilt 337 with the PX9 and 10 speed. But it does not have the DEF tank on it.
