Pete CAT AcertC7 On board Fault Code 25
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jlittle0018, Jan 4, 2016.
  1. jlittle0018
    jlittle0018 Bobtail Member
    18
    Acert C7.
    Got all my codes/logged events cleared off today. My problem has came down to the 25 code. However, the check engine light is not staying on all the time, just at certain times when the loss of power occurs. Would this code be logged into ET as logged event instead of active code since the light isn't staying on?
    Anyone had any experiences with this code?
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    25 has to do with the boost pressure sensor. Wiring/bad connection, or a faulty sensor is the most likely cause. It would be in ET as a logged fault code if it is not active at the time you check.
    jlittle0018 Thanks this.
  4. jlittle0018
    18
    Got a sensor ordered. Thanks!
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I'm not saying that it's the senor, I've seen more wiring/corrosion issues than bad sensors. Make sure you check the wiring before you spend money, Cat sensors are not cheap.
  6. jlittle0018
    18
    We checked the wiring today. Everything seems to be in good shape.
  7. Creswell81
    Creswell81 Bobtail Member
    41
    54
    Apr 7, 2020
    North Carolina
    I have a 2003 peterbilt 379 with a c15. The check engine light comes on in the last 4 gears when it's about time to shift gears and when I shift to the next gear it blinks 2 times and goes out. Only seam to do this under a load.
    Any idea what the prob is
    Also the flash code is 25 when I check the codes.
