Pete 389. Parking brake won't release, please help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Just.Do.It, Sep 2, 2019.
  1. Just.Do.It
    Just.Do.It Light Load Member
    55
    37
    Jul 23, 2018
    Tampa FL
    I got stuck on the side of the hwy, called mechanic, and he couldn't fix it. It started when I was cruising at 60 mph, suddenly air starts escaping through parking brake valve. I stopped on the shoulder, and that was it. Parking brakes locked, can't go nowhere. Releasing truck parking brakes wont wont do nothing, but I hear air going through the valve, near yellow knob. Also, I hear air escaping from valve assembly located on the cross member between rear axles ( don't know the name of it ). Mechanic replaced that valve assembly, but it didn't fix the problem. Any advice will be greatly appreciated!
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    All tractor brakes locked? The air you are hearing leaking from push valves and valve assembly on crossmember is usually a symptom of a leaking brake can
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You also have a new problem. Your brake air from wet to dryer and into the dry tank for your foot to stop everything is got too much moisture, oils and what not. Ate through the rubber divider in the service can and spring can at the wheel and push rods etc.
    Usually when a can goes like that when you use braking on foot your Primary falls like crazy followed by your secondary you have about 40 seconds to set it somewhere or get off it for the compressor to catch up. That will take a while with the low air in your ear.
    Just.Do.It Thanks this.
  5. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    Rear brakes locked. Mechanic said that brake chambers look fine, he couldn't find any leaks there. He pinched air hoses, one by one, to identify leaking brake chamber, but couldn't find any leaks there. So, now he says that parking brake valve assembly ( red and yellow knobs ) could be the problem. I kind of doubt it, because even though I can hear air escaping near red/yellow knobs, I cant feel any air going out of assembly. Air goes through it, and escapes from valve assembly located on cross member. Is there any another way to troubleshoot broken brake chamber? Again, mechanic pinched air hoses going to every chamber, and found nothing.
  6. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    Sorry, I didn't understand much. I am a newbie )
  7. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Ok. Im sorry let me think about it.
    You have a can that has a rod coming out to push all them pads on the wheel. It's about the same as your coffee pot or smaller.
    That can has spring in it. That is why you cannot move at all once those springs take hold. In half that can between Mr Spring and Mr Bigfoot (Thats you using the brake on the cab floor trying to stop...) is what normally keeps Mr Spring tied up in his corner so you can roll.
    There is a rubber disc just like a coaster under your beer on the bar. It's flappy. That seals the can and keeps Mr Spring and Mr Bigfoot getting along.
    IF YOU poke a hole through that disk every time you use your foot to stop... ALL your air goes out through that hole.
    Then you will stop when Mr Springs and company decides to apply.
    Does this help? Or would you like pictures?
    tucker and Just.Do.It Thank this.
  8. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    Yes Sir, now I understand that you are talking about possibly failed brake chamber. But mechanic tried to troubleshoot them all, he did it by pinching air hoses, trying to identify the leak from brake chamber. Said chambers are fine. Did he do it properly? Is it possible to identify faulty chamber by pinching the air hose?
    x1Heavy Thanks this.
  9. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Oh god I cannot tell you.
    If Mr wrench is a idiot then we all are idiots.
    If he knows whats what and can hear the #### air leak thats the problem everything else threatens to add more Mr Fix its feeding on Mr Wallet.
    When I pulled in with a bad can the shop man spun and said #### stop that right here, you get bad can under there...
  10. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    If you can figure out where the air is leaking that is the place to start. That part is both easy (noise) and hard (pinpointing noise by feeling with fingers).
    When you have that data, then we have something to chew on. Right now it's just hot air.
    EDIT: also, if you have an automated transmission, air could leak from one of the hoses to the actuators and that could prevent you making enough pressure to overcome the spring brakes. So put on your grubbies and go feel/listen around the trans.
    Just Do It gets real.
    x1Heavy and Just.Do.It Thank this.
  11. Just.Do.It
    55
    37
    Jul 23, 2018
    Tampa FL
    18 speed trans, no auto. Air noise is coming from two places -
    1. Parking valve assembly ( Red/yellow knobs. just a noise of air going through, nothing comes out of it, I reached around with my hands, couldn't feel anything ).
    2. Another air noise is coming from valve assembly located outside of cab, bolted to cross member, between rear axles. That thing was replaced yesterday, but problem still there.
    Both air noises I can only hear when Yellow knob pressed in. Pressure drops within 3 min to 40 psi, in both air tanks. Tractor wheels stay locked up on matter what I do. No air noise coming from any brake chamber. That's all I got. Thank you for reply.
