Pete 389 Drum to Disc conversion. Any advice?
Discussion in 'Peterbilt Forum' started by moraima80, Sep 29, 2023.
  1. moraima80
    moraima80 Bobtail Member
    Apr 16, 2014
    I have an 08 389 with drum brakes and are wanting to convert to disc. Anyone ever done that? Is there a conversion kit any company sells? Any input is greatly appreciated.
  3. roundhouse
    roundhouse Road Train Member
    3,130
    7,044
    Jul 11, 2018
    All 6 wheels ?
    Or just the steers ?
  4. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    All the mounts for the drum brakes and S cams have to be cut off and the caliper mounts welded on. Different hubs also.
    Last Call Thanks this.
  5. moraima80
    Apr 16, 2014
    All around.
  6. moraima80
    Apr 16, 2014
    I believe removing spider brackets removes all including s-cam bracket and chamber bracket. What I'd like to know is what caliper bracket can be used or if a different spider bracket is needed. And yes, a different hub.
    Nostalgic Thanks this.
  7. wichris
    4,243
    8,447
    Jan 17, 2011
    Spider bracket has to be removed.
    Spider/Caliper bracket has to be whatever system you're going to use. Meritor, Bendix, ect.
  8. 86scotty
    86scotty Road Train Member
    4,376
    11,620
    Aug 27, 2017
    Appalachia
    I'd go price calipers first and then you'll likely change your mind.
    Ssgtkevin and Last Call Thank this.
  9. wichris
    4,243
    8,447
    Jan 17, 2011
    Did you have to get new one(s)?
    That will get you to pop the end caps off once in awhile and squirt some graphite grease in them. LOL
  10. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Wouldn't it be cheaper just to swap the whole axles?! ... from wrecked unit
  11. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    This is the most Is feasible way ..IMO
