Pergo type flooring in a truck
Discussion in 'Ask An Owner Operator' started by Brickman, Sep 18, 2007.
  1. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    I'm getting ready to rip out some real nasty stained carpet from a W9 and want to put in Pergo type of hardwood flooring. I've seen trucks that had it, but don't know how its done. There is some trim edge that will hold some of it down, but not every where (like at the fire wall) Can I use flooring adhesive? or any other tips any of you that have done this might have for me.
    THANKS in advance.
  3. Attitude:)
    Attitude:) "Love each Day as if it was your last"
    510
    36
    Jul 13, 2007
    TX NM & CO
    What a great idea! It sure will look sharp:) You may want to look into the more expensive "Surround" tub and tile adhesive? Just a thought. It's pretty strong and may work better for you in that type area. Some of the adhedsives for flooring may become brittle. It may be worth your time to call some of the companies that make the adhedsives and tell them what you're using it for. You have extreme temp changes......
  4. wallbanger
    wallbanger "Enemy of showers everywhere"
    BMan, Pergo is a floating floor, so it won't work right if its anchored down. However, with the older style pergo (like we have in our house) the pieces have to be glued together, so it might work. The tough part would be molding it around the humps, angles, etc on a floor.
    What about an aftermarket wood floor kit? I have seen them in catalogs before (I think Rockwood), were you just thinking about doing it on the slightly cheap?
  5. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    I aint going with the custom wood floor kit. Not when I can buy a box of flooring at Lowes for $50 and change. I don't think it will take more than one or at the absolute most 2 boxes. The sleeper isn't that big.
    The biggest challenge would be the cab area angle where it goes from floor to the fire wall. In your house the floating floor is secured around the edges and that is more what I am looking at. By the time I tear out the old carpet and/or pad and then add in the thickness of flooring it won't be any thicker than what is already there.
  6. wallbanger
    Actually, the pergo will probably be thicker than the carpet, etc, and pergo recommends putting a foam barrier down between the pergo and the subfloor (or the cab floor) otherwise as it moves around it will squeak and groan! But even with some insulation and/or sound deadener, it will probably be thicker, but I doubt the difference would cause any problems.
    You may just end up having to make two sections of pergo, one slanted (behind the pedals) and one flat, and then figure out some kind of transition piece.
  7. Etosha
    Etosha World Citizen
    745
    50
    Aug 19, 2007
    Edmonton, AB
    You can also get fantastic vinyl with a wood design on that looks more like wood than wood does! Probably more durable too.
    Please take pics when you are done! It sounds like it will turn out FANTASTIC!
  8. any type of wood will expand and contract with temperature changes. If you try full glueing the floor..even though it is a "click together" floor, you are going to have some bonding issues. The biggest problem you will have is when the stuff get wet or damp it is going to swell and delaminate>basically fall apart. another thing, it will be very slippery when damp or wet.
  9. Vinyl will crack when it gets cold and it will also be very slippery.
  10. mikroos5
    mikroos5 Medium Load Member
    357
    31
    Nov 16, 2006
    Mass.
    Brickman if you need any pointers on installing laminate wood flooring in your truck let me know,my brothers have a remodeling business and they have installed it in RV's and many homes.
  11. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    To bend it properly you have to steam it 1st and use a mold of some type.:biggrin_2551:
