Have a 2018 Pete with x15 cummins. Oil temp runs about 220 and coolant runs 180. Is that the same as your?
People with x15 cummins. What’s your oil temp run?
Discussion in 'Ask An Owner Operator' started by Brandon0928, Sep 18, 2022.
Page 1 of 3
That's what mine does. I run in the evenings and at night, ambient temperature is normally in the 80s with lots of humidity.
mjd4277 and Brandon0928 Thank this. -
RockinChair Thanks this.
I'm a hotshot for Halliburton, so in a different truck every day.The 2019's we have seem to all be 180 coolant and 200 oil.The older ones ,2015 ,have always been 200 coolant and 220 oil.
Paccar engines in the 2019's,Cummins/Paccar in the older trucks.Theres a few older ones that have Cat engines.Brandon0928 Thanks this. -
I believe that their is a oil thermostat to keep temperature in the 220 range to burn off moisture in the oil or it becomes acidic..
Oxbow, jimmycrackcorn, Diesel Dave and 1 other person Thank this. -
Oil needs to be about 220 for all moisture to evaporate. Coolant will vary depending on load weight, temperature, uphill, downhill, and a few other variables. Coolant 180-200 is about the normal range and can climb up to 210, once again depending on variables. I’ve seen it as high as 225 on top of a hill but that was rare.
Vampire, shatteredsquare and Brandon0928 Thank this. -
X15 in my 2023 KW T-680. Oil temperatures hover right around the 210-220 range. Coolant will go from 177 to 210 before the the cooling fan kicks on. The past week or so I’ve been running around south where temperatures have been in the mid 90s(Mississippi,Alabama,Tennessee & Arkansas) and a lot of the loads I’ve been pulling have been around the 38,000 to 41,000 pound range.
230 in x15 565 hp with oil pressure around 35 and coolant at 180 running under a load
Our company “splurged” on the X15 Efficiency models which are rated around 400 h.p. but the fuel economy has been excellent!
Page 1 of 3
