People net
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by andrew871, Jan 20, 2023.
  1. andrew871
    andrew871 Bobtail Member
    7
    Is there a way to go back for the past week and look at how many miles was driven for that period? New to people net
  3. ducnut
    ducnut Road Train Member
    2,426
    7,204
    Dec 31, 2010
    SPI
  4. supersnackbar
    18,596
    44,699
    Aug 19, 2007
    Your Town, USA
    Go online and use the ELD Driver Portal. Just need to know what your company's code is, and then your user ID and password are the same as the unit in the truck
    Google Peoplenet ELD Portal, and then click on the ELD loging option (above the PFM login, that is where a company logs in) I tried to post the link, but it pulled my personal sign in info over with it.
  5. kemosabi49
    10,435
    44,381
    Jan 13, 2013
    SW Arkansas
    I can go to Logs, then to Details and the data shown includes your mileage. we can go back at least a week on our PeopleNet.
    25(2)+2 Thanks this.
  6. slim shady
    slim shady Road Train Member
    3,468
    14,689
    Sep 14, 2011
    Chicago, Il.
    Can't you look at your last 8 days?
  7. ducnut
    2,426
    7,204
    Dec 31, 2010
    SPI
    You’re exactly right!
    Until I just looked again, I didn’t realize, in the top-left corner, I could toggle back through the previous days. Ugh! I thought I could only see just for today.
    Thank you, for this.
  8. jdchet
    jdchet Medium Load Member
    535
    763
    Sep 3, 2012
    NE Ohio
    The ELD Portal on PeopleNet will let you edit and certify your logs. You may have to select "Request Logs" in the options menu from the Duty Status screen to update the vehicle unit. You can't edit drive time,but you can bail yourself out regarding duty time, if you know what you're doing. I believe you can go back 6 months on your logs.
    I suggest you "root" around the portal and check it out!
    JD
