Pennsylvania Hazmat Routing
Discussion in 'Hazmat Trucking Forum' started by sbeckley78, Feb 16, 2024.
  1. sbeckley78
    sbeckley78 Bobtail Member
    Feb 16, 2024
    Mansfield, Ohio
    Looking for the best way to run an Explosive 1.4 fireworks load from Cleveland, Ohio to York, PA. Is it better to run the I76 pike and take the hazmat detours around the tunnels or should I run out I80 and drop down to Harrisburg, PA? Looking for the best and efficient route.
    austinmike Thanks this.
  3. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    I would do 80-322.
  4. sbeckley78
    Feb 16, 2024
    Mansfield, Ohio
    thank you, is there any specific reason why this way would be better?
  5. MACK E-6
    48,113
    219,512
    There’s the Allegheny tunnel where you have to take US-30 or PA-31 between Somerset and Bedford, or drop down to I-68 on 219.
    To get around the next two east of Breezewood you have to drop down into MD anyway on 70 and go back up 81.
    @JoeyJunk ’s plan may or may not be a bit longer initially compared to running straight across the Turnpike, but it’s definitely better by the time you factor in the hazmat detours.
    JolliRoger, CAXPT, JoeyJunk and 5 others Thank this.
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    From Cleveland to York? I'd definitely be running 80/322/83. The tolls on 76 are ludicrous, and you gotta detour around the tunnels anyways. It'll be quicker to hop on 80 and hammer down
    Btw that load of fireworks may be going to my brother's place. He's planning a huge 4th of July deal...
    JoeyJunk, Jamie01 and austinmike Thank this.
  7. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    You'll have to exit the turnpike at Somerset and take PA-31 east to US 30, then take I70 east as there's truck restrictions on 30 east of Breezewood. 80 to 99 to 322 is the easiest route. Not to mention the weather on 31 this time of year is unpredictable. I've ran that route when it was 40 degrees in Somerset and it was 20 on top of the mountain with 6 inches of snow, all within 15 miles
  8. shatteredsquare
    shatteredsquare Road Train Member
    1,398
    1,825
    May 23, 2014
    middle dirt
    how heavy? 31 around Allegheny tunnel is obnoxiously steep and takes forever. I did it for fun to waste like 15 gallons and an hour for no reason. by fun i mean didn't realize you can in fact take class 9 bulk through the tunnels. just saw the sign and got off on instinct :confused:
  9. Dave1837
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Believe it or not if you're heading to I70 it's actually quicker to take route 31 to 30 as opposed to running through the tunnel. I've been passed by trucks pulling the hill before Somerset, then passed again by the same trucks on I70 east of Breezewood many times. The main reason is you avoid that cluster of red lights in Breezewood and all the S-curves on the pike after the tunnel
    shatteredsquare Thanks this.
  10. Artist#8
    Artist#8 Bobtail Member
    Aug 30, 2024
    I was on 76 heading west to Wilmington Ohio and I just happened to see the hazmat sign last minute. I got off of 76 and quickly found this post in my Google results and the directions that y'all gave really came in handy. Thank you people and stay blessed!
    Dave1837 and shatteredsquare Thank this.
  11. Dave1837
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    That's what we're all here for. Where was your starting point heading west? Breezewood?
