Passenger side wiper not working!
Discussion in 'Trucking Industry Regulations' started by Nairbfs79, Feb 13, 2018.
  1. Nairbfs79
    Nairbfs79 Light Load Member
    56
    33
    Apr 21, 2016
    Passenger side wiper motor went crap. Is this a dot violation?
  3. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    Yes. You need visibility out of that glass, too.
    They'll make crumbs in the floor a vio if they can't find anything else.
    Call it a trip hazard. (sic)
  4. jammer910Z
    2,446
    6,521
    May 28, 2015
    Also.. are you sure you have 2 motors??
    Could it be just the nut stripped/loose?
  5. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    Yes it’s a violation 393.78 but not an OOS violation.
  6. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    an "E" clip may have fallen off, or broke. i have had that happen ONCE, and i made sure i got a few to keep on hand for future instances.
    E clips look like these
    hardware stores, automotive stores sell either a package of all the same size, or a few of each size.
    i cannot seem to paste a pic here..
    could also be a nut under the arms cover that came loose. if so, carefully tighten it.
    baha Thanks this.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    fullsizeoutput_1a2.jpeg Make and model would help. Some have two wiper motors depending on vintage. If not inspect your linkages from wiper motor. If truck is equipped with two wipers yes they must both operate.
    sealevel and baha Thank this.
  8. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Yes but no real big deal
  9. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Your passenger does not need to see where you are going. Tell them to lay in the bunk & shut up.
  10. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    :biggrin_2559:
  11. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    In the meantime get some Rain-X. The stuff is amazing when applied correctly and a must have emergency item if you drive a older Freightliner.
