Parking on grass
Discussion in 'Questions From New Drivers' started by Lostmykey, Jun 20, 2020.
  1. Lostmykey
    Lostmykey Medium Load Member
    386
    521
    Oct 6, 2019
    Back on the farm, I’ve never had issues parking tractors on grass. Getting things unstuck were not issues either.
    I’ve been looking for secure truck parking near my sister. I found a mini storage location that allows truck storage. But, while there’s enough space to turn around on gravel; they require the trucks to back the trailers onto grass.
    The truck and it’s drives would still be on gravel; is there any risks for the empty trailer or it getting stuck?
    I’ve not inspected the site; my sister drives local; she’s looked at it and believes it’s acceptable.
    Coffey, DustyRoad and Doealex Thank this.
  3. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    (usually) if you make darn sure your drives are on solid ground, they'll pull an empty trailer out of anything. But get your drives on that grass after its been raining a lot, or its sand or loose deep gravel under the drives, all bets are off.
  4. 201
    201 Road Train Member
    12,052
    24,602
    Apr 16, 2014
    high plains colorado
    Well, that depends. I'd never park a loaded combination on grass, empty, I see no problem, as long as it hasn't rained a foot lately. I hauled a lot of cut hay out of fields, and loaded, it doesn't take much to sink.
    farmerjohn64 and Coffey Thank this.
  5. bad-luck
    bad-luck Road Train Member
    3,252
    5,954
    Nov 16, 2013
    Baltimore, Maryland
    You could get a 100 responses telling you you will be OK, and then get stuck. It's something that you need to take a look at for yourself. Yes generally if you keep your drives on the gravel and your trailer is empty and in the grass you will be OK but if it's a mud pit and your trailer sinks to the axles obviously you would be stuck
    farmerjohn64, Coffey and DustyRoad Thank this.
  6. TripleSix
    127,973
    Trucks already park in that lot? It should be packed down solid enough for you not to have any issues.
  7. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    This may sound stupid but I put a couple sheets of 3/4 plywood down on the ground and park the tandems on that. It distributes that weight across a larger area. If it rains it helps keep the ground drier under the tires. Not practical if you are using the spot once but if you plan on making it a frequent place it may be a good thing to do.
    Always lock your inter-axle when pulling out of the spot for more traction.
  8. Numb
    Numb Crusty Curmudgeon
    3,940
    8,771
    Jan 30, 2012
    Charlotte, N.Carolina
    marine plywood
    Coffey, Wicked Wizard and SmallPackage Thank this.
  9. Lostmykey
    386
    521
    Oct 6, 2019
    Actually, this might be the solution. I’ve used plywood for similar purposes in the past. If I get concerned about the weather, it’s good to have options; and I wouldn’t want to rut up their grass.
    Coffey and SmallPackage Thank this.
  10. Long FLD
    Long FLD Road Train Member
    11,378
    45,907
    Mar 4, 2015
    How many trucks are parking or have parked there before? Good chance it’s packed down enough for an empty. But the suggestion about putting the tandems on some plywood is also a good idea.
    Coffey Thanks this.
  11. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    You guys get to park on pavement?
    Coffey Thanks this.
  12. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Dry Dirt lots good
    Rain....Now you have mud...not good!
    Truck & Trailer empty weight is ? 36,000 lbs
    Do not drive or park on a grass lot
    201 Thanks this.
