Parking Lights Killed My Battery?
Discussion in 'Freightliner Forum' started by CluelessRoadie, Nov 18, 2020.
  1. CluelessRoadie
    CluelessRoadie Light Load Member
    56
    64
    Jun 20, 2014
    St. Joseph, MI
    I was sitting in the dock for 20 minutes. Left parking lights on. Now truck won't start. Brand new batteries. Is it likelier that it's my fault or something with the truck?
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    You should be able to leave your lights on for a few hours without issue. Definitely more than 20 minutes
    D.Tibbitt Thanks this.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    How old is the truck/starter?
  5. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    No, you should be able to leave the parking lights on over the weekend on a 34 or whatever and still be ok. there are 3-4 batteries at least. Something else is draining the batteries.
  6. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    It's the truck... you can leave the parking light on for 10 + hours and the truck will start just fine
  7. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Check the voltage of your batteries, if low I would wonder if your alternator charging properly? What is is voltage at the alternator and more importantly what is the voltage at the batteries? I would be checking voltage at each battery & see if it is different then any other battery.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I accidentally let mine on overnight, truck started fine.
  9. CluelessRoadie
    56
    64
    Jun 20, 2014
    St. Joseph, MI
    Yeah, I had recently had all new batteries and a starter. The starter is freezing up occasionally and so either it's a junk starter, there's a short in the wiring or they didn't wire it correctly. Thanks everyone
  10. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    i recently changed my starter myself.
    After I got everything back together when I tried to start, the starter did a few revolutions then it stopped and the whole dash went dark. Key off, back on, no computers, dash lights flashing.
    Rechecked everything was wired up right. Cleaned up the battery connections. Worked good after that.
