Parking brakes will not hold.
Discussion in 'Peterbilt Forum' started by Texas_incognito, Dec 12, 2012.
  1. Texas_incognito
    Texas_incognito Light Load Member
    59
    85
    Oct 9, 2012
    Texas
    2005 Peterbilt 379. The parking brakes on the tractor will not prevent the truck from rolling away. The brakes are in adjustment and the brake shoes and brake drums are in compliance. Is it possible for the spring to weaken with age preventing the shoe from being applied firmly to the drum when the parking brake is set?
    I got DOT'd yesterday and they did not find any problems with the brakes on the truck. On the axle where the parking brakes are located, the left push rod travel was 1/2 inch and the right was 3/4 of an inch, both were in compliance.
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You most likely have broken springs in one or both parking brake chambers, not applying full spring force to hold the truck.
    Texas_incognito Thanks this.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I have a similar issue with a bus with DD3 chambers. My issue, the brakes appear to be adjusted but, I have no park/service/emergency function. The mechanic was stumped.
  5. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Might want to check the S cam bushings along with the cans.
  6. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    You need to make sure when you set the brakes the.air is released might have a bad relay valve or quick release valve not letting the air from the emergency side of the cans
    Sheldon#1 Thanks this.
  7. CTE
    CTE Bobtail Member
    8
    I had the same problem on a truck and never did figure it out. The crazy thing was it had the best feeling brakes of any truck I had ever driven it was a 90 379 dump truck but the parking brakes wouldn't hold good at all.
  8. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Ditto: the broken Maxi spring
    Keep the cage bolt hole covers on that will keep them clean and last longer.
  9. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Springs broke in the pots, I had 3 out of 4 gone. Brakes worked fine, parking didn't.
