Parking at home
Discussion in 'Ask An Owner Operator' started by JustinKline, Oct 13, 2023.
  1. JustinKline
    JustinKline Bobtail Member
    16
    Jan 30, 2015
    I'll try to make this least detailed as possible, I'm moving back home to a company that will let me park at the house. I'm on 1.5 acre so plenty of room, the parking area that I can safely back into/ maneuver is grass and I'm thinking about parking there until I pave something.
    Anybody that went through this already, am I better off parking about 10 min from home at a small truck diesel gas station (only has about 7 spots so could be fight over space) while I pave the spot or will parking in the area actually help to compact the drive area first? Mud is my only concern but it doesn't rain much in winter here. I would save up to do this next spring.
    Also is 4" concrete with 2" aggregate base good enough, won't park loaded and I'm not going for a stained beauty just function.
    Thanks for any help.
  3. kylefitzy
    kylefitzy Road Train Member
    4,598
    18,984
    Aug 12, 2007
    Kansas city,Mo
    Why concrete? I put down a layer of road fabric, then 4-6” of 4” minus gravel. Eventually I’ll put some 1” minus on top to smooth it out. It’s pretty rough but very solid, and I have driven 80k plus across it.
  4. JustinKline
    16
    Jan 30, 2015
    My neighbor.. this will be directly across from his driveway, couple years ago I built a gravel RV pad and he's made it obvious how much he hates gravel. My next door neighbor let me know it's because my house had a gravel driveway for years and he was always fighting with previous owner about rocks all over his property, his mower had broke some windows.
    Also, I would rather do asphalt since road is, it's cheaper too. Good idea and how to do it?
    blairandgretchen Thanks this.
  5. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    If money isn’t a problem then sure - go for it.
    It’s nice of you to placate the neighbor, but @kylefitzy suggestion is what I did and it’s a heap cheaper than blacktop or concrete.
    dunchues, Oxbow, cke and 5 others Thank this.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Figure out of it's legal to park commercial vehicles and equipment on residential property in that jurisdiction. If it's not legal, you can try your hardest to appease the neighbors, but they could always complain to code enforcement for any reason. Don't assume that just because other people around you are parking trucks on their property that it's legal, either.
    buddyd157, gentleroger and Numb Thank this.
  7. Stringb8n
    Stringb8n Road Train Member
    1,549
    1,924
    Sep 27, 2015
    If you don't care about beauty, just put some regular one and a half or two inch crusher run (basically just rock) on it. If you want to make it look "nice" put screenings on top of it. I am not sure how much that would cost, but I would think but don't know for sure that it would be a lot cheaper than what you are thinking about doing.
    gentleroger Thanks this.
  8. ducnut
    ducnut Road Train Member
    2,440
    7,257
    Dec 31, 2010
    SPI
    4” of concrete won’t even come close to supporting a semi. My previous driveway I poured at 12” and supported my bobtail with no problem.
  9. Knightcrawler
    Knightcrawler Road Train Member
    1,263
    4,318
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Structure magazine says 8 inches will support a fully loaded concrete truck. 6 inches is enough for an empty. Axle weights should be similar I would think to a 5 axle 80,000 or an empty.
    Flat Earth Trucker and Opendeckin Thank this.
  10. rollin coal
    rollin coal Road Train Member
    13,087
    25,913
    Mar 29, 2008
    TN
    4" of 4,000 psi concrete is plenty to support a semi it won't crack it. I wouldn't waste money on concrete you'll definitely get sticker shock contracting it out. Scrape the grass off, spread and push in some 1-1/2" rock, then cover that with crusher run and do the same. That's all you need for a parking spot. The neighbor probably didn't do a good job on his rock is why he hates it.
    Old_n_gray, 86scotty, lester and 2 others Thank this.
  11. ducnut
    2,440
    7,257
    Dec 31, 2010
    SPI
    4” concrete is a sidewalk.
    Vampire and Opendeckin Thank this.
