Parked regen taking too long
Discussion in 'Experienced Truckers' Advice' started by Ranabha, Apr 17, 2017.
  1. Ranabha
    Ranabha Bobtail Member
    Hi,i have 14 pete 579 with paccar,usually i need parked regen after 8-9 months but 1800 miles ago i had a parked regen that took 2 hrs now again i got a sign and i am on parked regen from 4 hrs and still counting.. is it normal?
  3. Ranabha
    my truck ask for parked regen once in 8-9 months before but last time i had a parked regen 1800 miles ago,it took 2 hrs but now i again i get a light 3 hrs ago and since then it is doing parked regen and still counting.is it normal.
  4. Ranabha
  5. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    No not normal. Even if you idle all night it shouldn't take more than an hour.
    It also sounds like it's stopped doing any passive regens, meaning when your rolling down the Hwy. You need to get it to a shop asap.
  6. Finfn1372
    Finfn1372 Road Train Member
    1,912
    3,476
    Aug 7, 2014
    Greenville,NC
    No the dealer told me one shouldn't take no more than an hr,you need to contact somebody.
    Ranabha and driverdriver Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I bet it's hotter then hell inside that truck. Now would be a good time to make sure your belongings in the truck are covered on your renters or homeowners policy.
    Rusty Trawler Thanks this.
  8. ethos
    ethos Road Train Member
    4,249
    9,905
    Mar 3, 2013
    Houston
    Way above normal. Longest I've ever had a recent gobs an hour. At 5, I'm shutting the down because clearly something has gone wrong. I do admire your persistence though.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    When was the last time the dpf was cleaned out at a dealer?
    driverdriver Thanks this.
  10. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    How many miles on engine, is it using coolant/oil and how much?
  11. Brandt
    Brandt Road Train Member
    4,403
    5,936
    Sep 17, 2012
    Like other said DPF is probably full and needed taken out to be cleaned. Around 400,000 miles they need to be pulled out and cleaned. Or the doser injector could be clogged and it not regening while driving. Sounds like it time to see the dealer.
    driverdriver and mitmaks Thank this.
