I'm sorry I'm sure this has been talked about before, but I'm running a tractor trailer for 8 consecutive days and 8 days only in August. Can I run paper logs?
Paper Logs 8 Days or Less Rule
Discussion in 'Trucking Industry Regulations' started by MercySakesAlive, Jul 27, 2023.
what are you doing with the truck? the reason i ask is because if it is for personal use, then no log book required.
MercySakesAlive Thanks this. -
it is for work
Is this your company or are you working for someone?
How old is the truck?
Do you have an ELD installed in the truck?
If so, is the ELD functioning?
If you don't have one, then you may have to prove you are getting one and do paper as a "backup".
Paper isn't the problem, it is the circumstances in which you are using the paper that matters.tscottme Thanks this. -
12 ga, Oxbow, Diesel Dave and 1 other person Thank this.
Not an interrogation @MercySakesAlive but this is an important question. Do you normally drive a CMV that requires logging?tscottme and MercySakesAlive Thank this. -
tscottme, Bean Jr. and MercySakesAlive Thank this.
Assuming none of the dates listed qualify for a time card exemption, legally you have to run an ELD as you are now outside the 8 days in 30 exemption. Well unless you are doing something else that is exempt like transporting the truch itself.
