Pallet configuration for heavy loads?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Jan 25, 2018.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    Is there a pallet configuration you guys might recommend for hauling heavy produce such as oranges to keep my axle weights legal. Someone mentioned a 1, 2, 1 then 2 the rest of the way. Any other configurations you guys might recommend?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    How many pallets and how heavy are they each?
    Need to be California legal or no?
    Usually 1 2 1 2 2 2...... works. Not always. I do things a little differently...
    It helps to have air gauges for your drives as well as your trailer tandems... it's a luxury for most, I know..
  4. Allow Me.
    10,718
    12,404
    May 28, 2009
    Rancho Mirage, Ca.
    You need some basic info to estimate. 1. total weight 2. how many pallets total. 3. Are all pallets identical in weight ? 4. Can you double stack ? 5. How sturdy are the pallets ? Some shippers stack then shrink wrap really good or just so-so. Can the bottom pallet hold the weight of the top pallet if you do double stack. Normally on a 53' trailer you don't load past the 48' mark, so your payload is taking up 48' of trailer space. A good rule of thumb, single, double, single then double the rest of the way. This is with heavy pallets, like 2500lbs each.
    NavigatorWife and Jdm5jdm5 Thank this.
  5. Moose1958
    Moose1958 Road Train Member
    15,255
    33,805
    Dec 17, 2010
    Williesburg, Virignia
    I have to 2nd this comment. In my driving career I rarely had all my pallets to weigh the same or be stackable. It is just not something most shippers do.Because of this it is hard to (just) load based on a set pattern.
    Jdm5jdm5 Thanks this.
  6. mitrucker
    mitrucker Road Train Member
    5,402
    9,954
    Dec 15, 2010
    Lapeer, MI
    When I used to pick up water with a reefer, it was 18 pallets total, 43,500 lbs. They were loaded 1-2-1-2 all the way back.
  7. Jdm5jdm5
    193
    60
    Apr 13, 2016
    Yes, I pickup in California and take the load to North Carolina. The loads are different each time as far as number of pallets, and pallet weight. But they're typically always heavy. But was just wondering what configuration typically works for heavy produce loads.
  8. Jdm5jdm5
    193
    60
    Apr 13, 2016
    Would you still be in front of the 48' mark with this configuration....or is it not a big deal to stack all the way to the trailer door with this configuration
  9. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Typically 1212222..... works fine. Do you know your empty weight?
    And do your trailers have extra holes in front of the Cali 40' hole? You should know exactly which hole to be in to be California legal.
    Never load heavy all the way to the doors you will never be California legal. Only produce all the way to doors are lettuce, strawberries, loads where gross weight will not be an issue.
    Do you usually scale out in the 78 range or are you gambling with 80 and playing the fuel game as well?
  10. Snoopycda
    Snoopycda Medium Load Member
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    I just keep the weights for tandem tractor tandem trailer to 1000lb per foot of trailer (2000lb per skid) out to 48' for no more than 48,000lb payload. (And when pushing this max, you better be bang on) 53' tandems are still limited to the same payload as the 48's are.
    if you have a tri-axle trailer the rear half can be loaded to 1200lb per foot.
    These easy formulas work up here in Canada, not sure about down south, but at least you can build on the same idea.
  11. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Typical "heavy" produce will range in the 42-44 usually. The issue is loading it so as not to exceed 34 on drives or trailer as well as comply with 40' kpra and if you have the max 35% rear overhang you also must be good for that. All without cutting any off the load if possible.
