Painting fairings?
Discussion in 'Ask An Owner Operator' started by Batman13, Oct 20, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    What paint would I use for the fairings? For a freightliner cascadia...not painted so it's just the pvc..
  3. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    If you want to paint it the same color as the truck, then you need to find out what the paint code is and find out what type of paint it is, whether it's imron or whatever kind of paint they used.
    Then when you call the paint supplier for the paint you tell them that it's imron or whatever type of paint it is and what material that you are painting.
    I know that with rubber bumpers they can sell you the same paint but it's a different formula or something made for the rubber.
    But if you call them they can tell you what you need for that if it's something different, which most likely it is.
  4. Ridgeline
    22,112
    113,286
    They are not pvc.
    86scotty and Klleetrucking Thank this.
  5. Ridgeline
    22,112
    113,286
    Just get a single stage epoxy paint, no need to go to fancy and expensive.
    BoostedTeg, Dale thompson and Big_D409 Thank this.
  6. 86scotty
    86scotty Road Train Member
    4,375
    11,615
    Aug 27, 2017
    Appalachia
    If I'm ever painting any trim or doing body repair on the lower side of my truck I'm coating it with bedliner. Specifically, Raptor Liner. You can get a DIY spray kit for $100 on Amazon and get matching tint base for it if you want to color match. The stuff is bulletproof.
    Here’s a van I sprayed a few years ago. I am not at all a painter. FDC9D3D0-90B2-4D99-93A4-609525E6D61A.jpeg 1CD310BB-902E-46AA-9228-5B5A73DC6DB1.jpeg 773C77ED-AF63-4201-A6E7-F22069D4C2BE.jpeg
    Crude Truckin' and Long FLD Thank this.
  7. Dino soar
    4,789
    26,858
    Dec 8, 2017
    I haven't done any of that kind of work for a while but I've been thinking about this.
    If you call the paint shop they'll tell you what to do but I think there's an additive that you put into there for a different material like rubber.
    But now that I'm thinking about it I think those fairings are fiberglass.
    If so, I think you should be able to just paint them the same as you paint your hood but I would still check with the paint shop.
  8. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    They're a glass composite, can just scuff good and paint. Better to use a bonding sealer first. It will be imron elite bc/cc. Be prepared for sticker shock.
  9. autopaint
    autopaint Light Load Member
    140
    359
    Jul 26, 2019
    If the fairings are fiberglass or SMC, you want a couple of coats of epoxy primer before you either topcoat with a single-stage (has color mixed in with the clear) or basecoat (the truck's color) and clearcoat.
    If the fairings are plastic, you need to know if they are a thermoset type plastic that requires an adhesion promoter before the epoxy primer.
    The way you can tell is, take your pocket knife and cut off a tiny little piece somewhere behind the fairing.
    Put the piece of plastic in a cup of water. Does it float? The saying is, if it's a floater, use a (plastic adhesion) promoter. If it requires a promoter and you don't use one, your paintwork can peel off in sheets. If you don't follow the promoter's directions, it can peel off in sheets.
    I left out a few more specifics if anyone wants to learn more about the prep work and technique.
    '88K100 and Dale thompson Thank this.
  10. wichris
    4,243
    8,447
    Jan 17, 2011
    Fairings are SMC, bumpers are plastics.
  11. autopaint
    140
    359
    Jul 26, 2019
    Thanks. I'm not familiar with every model out there, so I didn't want to make a blanket statement.
