painting aluminum fuel tanks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BryRylanKW, May 31, 2011.
  1. BryRylanKW
    BryRylanKW Light Load Member
    118
    17
    Feb 1, 2011
    cape cod MA
    I see alot of trucks with painted tanks. What paint and primer and you guys using? my tanks are in ruff shape I rather just paint them and be done with it rather than be polishing all the time.
  3. rollin coal
    rollin coal Road Train Member
    13,083
    25,863
    Mar 29, 2008
    TN
    You'll need to sand and prime them with zinc chromate primer. For cheap you could sand and wipe them down with vinegar then use regular primer but it probably wont hold up. Do it it right prime it with zinc chromate. Paint with Imron I believe it's a Dupont brand.
    jr-transport Thanks this.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    you can get a tank vinyl tank wrap for them---just have to be very clean before putting it on--or you can go all out and get a stainless wrap as well
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Don't wrap them in stainless! Yes, it looks very nice but the tanks will not last very long. They will pit and leak.
    Adisiwaya Thanks this.
  6. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    what about priming them before the stainless wrap?---i can see the corrosion being bad with two disismialar metals if some protection isnt taken
  7. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,954
    Jan 18, 2011
    IMHO--there are many ways to accomplish this--BUT if it were me I would have them powder coated professionally--powder coating has come a loooong way in recent years and offers as many colors etc--as paint and holds up much much better
    canuck in da truck Thanks this.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Fuel tanks on a modern engine get very warm nowadays, One of the best power improving techniques is to add a fuel cooler on the return line. Painting or wrapping the tank, will block heat transfer. I have seen many trucks with a winter wrap that was made from a quilted product. Usually just to cover the front section.
  9. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    I would agree with getting them powder coated otherwise DuPont has a etching primer that you could use to help bond the paint (Enron) to the tank.
  10. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    I have painted a lot of aluminum and self etching primer is only good for small parts that dont see much abuse. I wouldn't use it on tanks my self. Painting aluminum is a 5 step process. First you need to clean it with a special cleaner made just for aluminum. The second is the most important. You need to scrub it with a special etching liquid and a scotch bright pad.(Just like sanding before painting. Don't miss anything) This liquid is made just for painting aluminum. The third is to rinse throughly with water. After it dries you need to prime it with an epoxy primer. Epoxy primer is buy far the most durable on aluminum. You need to paint as soon as the epoxy primer is dry to the touch. You do not sand the epoxy primer. Just paint over it. Usually about 20 minutes flash time before paint. Use a urethane type automotive paint. Single stage or base clear is fine. Duponts Imron ain't what it use to be. They changed the formula years ago to lessen the VOC's (Volatile organic compounds). Its still good paint but I wouldn't go out of my way to find it. All the current automotive paints are very durable. This will give you as durable of a finish as paint can give. With all that said tanks take a he!! of a beating and I do think power coating will hold up better. Bad part of power coating is the down time. You will need to send you tanks out and they will need to be completely drained and free of fuel. Hopefully you can find some one to do it fast and have minimal down time. You could do the paint your self in a day and reinstall the tanks the next day. The power costing will most likely be more expensive. Just a rough estimate of about $250 for the painting materials. Buy the way I use PPG products but all the paint manufacturers have the same type of products for painting aluminum. If you want the names of all the different products I talked about I can get them for you but it will take me a few days. I don't do it every day and I don't think I have any right now. Ill have to call my supplier and get them. Hope this helps.
  11. Starline
    357
    251
    Jun 1, 2011
    Middle Tn
    What about rhino liner coating ?
