Paccar MX13 Oil module replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Volvotech8080, Dec 6, 2018.
Page 2 of 2
Yes the tubo will have to be removed and in a kenwort t800 the motor mount will have to be loosened up to get it out.
Also need some help with the diagram on mx-13 for the water pump and thermostat replacements
Since you replacing water pump and thermostats you may consider removing the entire cooling module for access to remove the oil module. Pretty certain the oil cooler wont come off the module with the module in chassis. Big Job....
Diagrams attachedAttached Files:
BoxCarKidd and spsauerland Thank this. -
Page 2 of 2
