Paccar mx13 code help.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oldironfan, Jun 10, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    The top code shows high EGR pressure. I'm guessing it's stuck or done. I heard one big cough than that was all. Just over warranty at 403,000 miles. Check light stays for engine in yellow.
    Thanks for the help.
  3. Lightning McQueen
    Lightning McQueen Bobtail Member
    14
    What happened with that I was thinking maybe your cooler was clogged or DPS sensor was bad
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You don't list any FMI with your fault codes- Get hooked up and get a P code and we can get somewhere.
    1209 is related to Pre-turbine exhaust pressure issue- Tis the sensor with the tube directly off the exhaust manifold.
    3821 is EGR engine derate most likely related to above -P1496
    The 77 doesn't come up for me as engine related.
    If this is an EPA17 engine- the tube fittings crack and break at the sensor manifiold. I have also seen the pressure sense tubes plugged with a slug of carbon with high idle or light load engines
    pushbroom Thanks this.
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Its from 2018 :)
    spsauerland Thanks this.
