Paccar head gasket permanent repair solution
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Truck engine machinist, May 15, 2020.
  1. Truck engine machinist
    Truck engine machinist Light Load Member
    195
    185
    Dec 2, 2011
    USA
    I am now fully convinced, that Paccar has a problem, with soft counterbores on front and rear cylinders.. I am finding many,many, times, that the #1 and/or #6 counterbores are badly fretted, even though the liner protrusion, is well within spec.(.006"-.0065"). I am told, that when manufacturing compact graphite iron, it requires a very complicated process of heating and cooling. It appears that the front and rear cylinders are not heat treated, correctly. I even had one re-fail, after a very short time, after machining the counterbores to max protrusion. I am now cutting any, badly fretted, front or rear cylinders, for a stainless steel shim. Being, a dissimilar metal, it is less likely to fret, even if it does move, in the block. The one that had re-failed, and now, has a stainless steel shim, has now been working well, for a long time.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I'd have to browse through the old newsletters, but I know Paccar said they were having issues with counterbore fretting on higher HP family engines on EPA 17. Solution was to go from lower press fit of liner to upper press fit and they made change to all blocks going forward.
    Oxbow, pushbroom and Shawn2130 Thank this.
  4. Truck engine machinist
    195
    185
    Dec 2, 2011
    USA
    I'd be interested in more info on this. Thanks
    Oxbow and Shawn2130 Thank this.
  5. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I'll dig it up.
  6. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    Does this mean that press fit sleeves of the past are better than what the manufacturers do now?
    Accidental Trucker Thanks this.
  7. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    This is the best way I can show you the changes Paccar made to cylinder block and liners. Fretting was being found more in higher HP engines. Must have seen it early on because plans to make change were June of 2017. All engines went to new design 5th week of this year. Kinda ironic, Cummins fix for there counterbore issue's in the mid 80's was to go from upper press fit to lower press fit. 30 years later, Paccar is doing the opposite.
  8. Jigfromtn
    Jigfromtn Bobtail Member
    Fella please elaborate on your findings. We too have had repeat failures on the counterbores. Cutting them to the top end spec does nothing to ensure the liners are pressed firmly. As you mentioned, we are seeing it in the 500 HP range. Dissimilar metals causing severe corrosion and cavitation problems on the deck surfaces. We have seen one fail repeatedly on cylinders 4,5,6. Distinctively so, as the coolant surrounds those cylinders and eliminates corrosion build-up, while the cylinders unaffected are packed with rust around the liner. We have cut two this year, and both are showing signs of repeat failure. One has repeatedly leaked coolant through the head-gaskets only opening between 3 & 4 directly behind the turbo on the hot side and the secondary fuel module on the cold side.
  9. Truck engine machinist
    195
    185
    Dec 2, 2011
    USA
    You say dissimilarmetals caused it. The liner and the block are similar metals. I an cutting the bad ones, for stainless steel shims. That seems to correct the problem.
  10. Sergio001
    Sergio001 Bobtail Member
    USA
    Hello. I have the same problem witn EPA 17 engine, only with the second cylinder. Please tell me where you bought steel shim and what part number?
