P-Pump Cummins question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DRTDEVL, Apr 5, 2022.
  1. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,419
    Jan 27, 2013
    Austin, MN
    OK, truck is a 1998 F800 with a 5.9 12 valve and Fuller 6-speed. The truck was spec'd at 210 hp. I think that's 420 tq or so. The trans/clutch are good to 660 tq.
    If I put in the 3k gsk and replace the fuel plate, what fuel plate would bring it up close to 650 tq, and about how many hp would that be? I'm guessing I'll probably have to think about another turbo as well, but not sure about that.
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    If your pulling somewhat heavy for that size I wouldn't turn it up too crazy. You can also do the Mack rack plug. It will give the rack an extra 2mm of travel up to 21mm. Bump the timing up 1-2 degrees, nothing radical.
    Here's some diff cuts. Pyro is also needed if you don't have one
  4. DRTDEVL
    1,706
    3,419
    Jan 27, 2013
    Austin, MN
    Thanks for the graphics there. Pyrometer is definitely on the menu, and it doesn't pull heavy at all. I bought the truck in the CA IE with the intention of flipping it up in the Midwest, but it is too sweet of a tow rig that I am probably going to keep it and make it the way I want. 20' flatbed will be extended with a 4-5' beaver tail, and a large slide-in camper for a pickup will be mounted up front. My Land Cruiser will ride on the rear of the deck/beaver, so I would estimate about 4k for the camper max and 7k for the Cruiser... 12k on the back, with a 26k GVWR at about 23-24k overall (I really need to get it on a scale to see its true tare weight, but I am guessing about 11-12k there).
    The GSK is about ability to hold 65-70. Right now it will hold 68 mph all day when unloaded, but put my empty car trailer behind, and that drops to 66. Throw a vehicle on it, and 64 becomes the max cruising speed due to the fuel cut winding down as it approaches 2500. I don't need a speed racer, but something that can climb a grade at a reasonable speed and run 65-70 on the flat lands would be nice.
    One more question: Being only 210 factory hp, should I also be looking at bigger injectors? How much will those stock injectors support?
  5. LameMule
    LameMule Road Train Member
    1,147
    7,399
    Jan 19, 2020
    Montana
    Don't turn it up unless the person driving it has enough common sense to keep the rpms up and egts down.
    Bumping timing helps a ton with power and fuel mileage.
    Adding fuel is only helpful within the useful range of your turbo and headgasket. Too much fuel on a stock turbo and you'll be making heat instead of power. Too much boost from over fueling the stock charger and you'll lose the headgasket.
    Adding power is best done as a full system rather than a single part or adjustment. Bigger nozzles need a bigger injection pump which needs a bigger lift pump. All that fuel is useless without more air from a bigger turbo or cleaned up airflow in and out of intake and exhaust. Without headstuds, you're on borrowed time...
    Look up 12 valve hp recipes it will give you a rough idea of the extent that things snowball as you aim for higher levels of hp.
  6. DRTDEVL
    1,706
    3,419
    Jan 27, 2013
    Austin, MN
    I will be the only one driving it.
  7. DRTDEVL
    1,706
    3,419
    Jan 27, 2013
    Austin, MN
    Funny thing, I looked up "1998 F800 specs" online to see if I could narrow down the torque number, and I found the truck I bought listed online at a dealer. I bought it last year from the guy who I assume bought it at this dealer and he fixed it up real nice in the whopping 3k miles he drove it, removed all the old company markings, and cleaned it up pretty decently
    1998 Ford F800 -.
  8. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    I wouldn’t even drive it without a pyrometer. Way too easy to get it too hot and melt something.
  9. Brettj3876
    11,257
    54,056
    Nov 18, 2014
    Land of local
    For what you're doing the 12mm pump will be more than enough. About 550cc is the max for à 12mm with it opened up all the way with full cut delivery valves. Close to 700-750hp with a stock pump is the numbers I've heard. Obviously you probably don't plan on going that high.
    They use the same 12mm pump on the early E-7 Mack. More than enough for your 12V.
    I would head over to a Cummins forum them guys will set you straight with what injectors and turbo to use
    God prefers Diesels and LameMule Thank this.
  10. Brettj3876
    11,257
    54,056
    Nov 18, 2014
    Land of local
    God prefers Diesels Thanks this.
  11. MacLean
    MacLean Road Train Member
    1,268
    3,716
    Sep 12, 2017
    I would not turn it up and work it without studs & rings. Those Cummins Love to spit head gaskets out when making any amount of power without head studs.
