P&d local delivery
Discussion in 'LTL and Local Delivery Trucking Forum' started by Ddr1992 579, Jan 24, 2021.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Is it possible to only do p&d local delivery routes with a company like conway, xpo, old dominion freight, yrc and other ltl companies? I like loading and unloading trucks so p&d sounds like a good idea and dock work wouldn't be too much of an issue... would a cdl license with air brakes and hazmat be good for running local p&d routes?
  3. McUzi
    McUzi Road Train Member
    1,479
    3,838
    Jan 14, 2018
    Conway is XPO.
    Yes you can run p&d only.
    You’ll need a tank and doubles endorsement in addition to the class a and hazmat for the major LTL players.
    Texas_hwy_287 and Opus Thank this.
  4. 201
    201 Road Train Member
    12,047
    24,586
    Apr 16, 2014
    high plains colorado
    Still pondering, eh? Local P&D usually gets snapped up by senior drivers and you'd probably start as a line haul driver. Still regional, but a different job. I say, work on the dock, maybe move some trucks around, and jump in that way. To tell the truth, with the way traffic is, and pay rates, you may make the same on the dock and maybe like it better. Biggest plus with dock work, 3:30 is out the door, not, "oh, can you make one more pickup" ( at 3:30, mind you, on other side of town in rush hour). That gets mighty old.
  5. Chinatown
    Chinatown Road Train Member
    73,251
    164,554
    Aug 28, 2011
    Henderson, NV & Orient
    I worked with several drivers that applied with Saia and Estes. They all threatened to quit if they were put on P&D because the big money is in Line Haul. Guess what happened; they were all put on Line Haul.
    201 Thanks this.
  6. freebeertomorrow
    freebeertomorrow Heavy Load Member
    908
    1,712
    Mar 19, 2016
    Indiana
    it's the complete opposite. with no experience he will start out doing p&d. most places want at least 2 years exp with all endorsements and 0 accidents before theyll even consider one for linehaul.
    i know criteria is changing, though. not for the better.
    201 and Opus Thank this.
  7. Ddr1992 579
    395
    100
    Sep 10, 2018
    what I'm looking for is solely p&d delivery routes driving either a box truck or single axle delivery tractor with a pup with lift gates and pallet jacks... no doubles or triples... which companies use that set up as solely running delivery routes? Do ltl companies do that?
  8. MACK E-6
    48,113
    219,512
    That depends on the company, or the terminal, and how they operate.
    When I first started with my outfit, they put me right into a linehaul run, and most of ours pay less then a typical day at top scale for the city guys.
    I’m thinking the majority of the high dollar linehaul runs are to be found out west.
    201 Thanks this.
  9. MACK E-6
    48,113
    219,512
    Why not just jump on board with a company and take the first city bid that opens up?
    That will be your job from then on.
  10. freebeertomorrow
    908
    1,712
    Mar 19, 2016
    Indiana
    id say you are right and job placement is company dependent. pitt sees linehaul as the golden child. i don't want to say they play favorites, but we're the favorite. city is where one starts otherwise. when i hired on (straight to linehaul), i want to say i needed at minimum 6 yrs exp, 3 yr clean record to even be eligible.
  11. Ddr1992 579
    395
    100
    Sep 10, 2018
    Do p&d drivers load their trucks and trailers or do the dock guys load? I like loading and unloading trucks so if there driver's do it won't be too much of a problem
