Owner Operator CNG truck
Discussion in 'Ask An Owner Operator' started by shatteredsquare, Jun 28, 2023.
  1. shatteredsquare
    shatteredsquare Road Train Member
    1,398
    1,825
    May 23, 2014
    middle dirt
    never seen one besides UPS or some other fleet truck super clean and mirror polished, definitely not a farm truck, i seen one white one today south of milwaukee on 94 dirty af wobbly fenders looking like mad max with a stack of IFTA stickers pulling a bashed up hopper just like all the other beat up ag trucks. makes sense if fuel is that much cheaper? wonder what the reliability is like
  3. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    I was told by a mechanics wife that is the Cummins tech at Freightliner that they go through a lot of heads. At least I think thats what she said.
  4. JoeyJunk
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    Waste Management runs them and they are always at the dealership needing repairs. I’d like to talk to a WM mechanic to get their view.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Fuel is cheaper but uses twice as much apparently. Shorter range as well
  6. Hammer166
    7,341
    26,340
    Aug 18, 2007
    ~8600+' and loving it!
    Doesn't it drop the torque a bunch, too?
  7. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    When I was doing heavy towing I towed a ton of Frito Lay Volvos than were CNC. They were always having issues.
  8. shatteredsquare
    1,398
    1,825
    May 23, 2014
    middle dirt
    they can just convert a diesel block to run on CNG? i figured it would have to be some high RPM beehive situation and redo all the gearing to get any usable torque out of fart gas
  9. MadScientist
    MadScientist Light Load Member
    99
    144
    Dec 14, 2019
    Back in the 1990s the company I was with hauled a lot of stuff for Cummins' mid-engine program. That was their 5.9L and 8.3L inline six cylinder engines as well as the associated 4 cylinder blocks with the same bore/stroke as the B6 and C6 blocks. We'd haul everything from rough castings, screws, bolts, pistons, crowns, heat exchangers, turbos, etc., heat treated parts, machined parts, coated parts to the finished engines going to Chrysler, Onan, Case, Freightliner (A lot of FL bus chassis had the 8.3L), RV manufacturers, etc.
    There were LNG and CNG versions of all of those engines. The only basic difference were the heads. They had spark plugs, different compression ratios, and different valves. Most of them wound up out in the desert SW as stationary irrigation pump prime movers fed by natural gas lines.
    Ruthless Thanks this.
  10. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    937
    Jan 11, 2022
    That natrual gas stuff scares me I try not to mess with it
  11. W923
    W923 Road Train Member
    1,296
    3,924
    Feb 28, 2022
    If you’re in an area where you can fill it maybe it’s worth a try. Around here you better be able to go a long way on a fill…I can’t even think of a place but maybe that’s because I don’t look. I have no idea at all about the reliability or any other concerns with it
