Oversized load driver issued multiple citations for bridge strike caught on camera
Discussion in 'Heavy Haul Trucking Forum' started by truckaholic001, Nov 14, 2019.
  1. truckaholic001
    truckaholic001 Light Load Member
    113
    311
    Apr 25, 2016
    Nevada
    lynchy, magoo68, LoneCowboy and 4 others Thank this.
  3. AModelCat
    154,529
    This is why you don't tailgate.......
    Coffey, buddyd157, D.Tibbitt and 8 others Thank this.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    Now he can deliver the new & improved collapsible container box
    buddyd157, D.Tibbitt, Opus and 5 others Thank this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    what about tailgating a escort
  6. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    I saw a new one, today, in IL.
    A bucket truck with a large pole was following the lead escort a long way in front of the load.
    The load was really tall, looked like he had to get off to go around the overpasses, the bucket was apparently to lift overhead lines.
  7. Driver312
    Driver312 Bobtail Member
    4
    Sep 25, 2019
    that bridge is very low, you can see it on
    FlaSwampRat and truckdriver31 Thank this.
  8. JonJon78
    JonJon78 Road Train Member
    7,042
    37,578
    Jul 1, 2018
    Isn't there signs on 43 in Milwaukee advising trucks over 13'6 or overheight to exit? Pretty sure there is...
    D.Tibbitt, cke, FlaSwampRat and 3 others Thank this.
  9. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,190
    Aug 26, 2014
    LLMF
    Don't they have height detectors as well?
    D.Tibbitt, cke, truckdriver31 and 3 others Thank this.
  10. Razororange
    Razororange Road Train Member
    2,452
    23,206
    Dec 20, 2011
    Milwaukee, WI
    Generally the OS route around Milwaukee is HWY 100 which runs a big loop around the county. Even that has a few low bridges though. For the most part over height on the Milwaukee Interstate routes is not a good idea unless you know where you're going.
    That bridge he hit is Lincoln St. It's clear for up to 14'11". He was likely well over 15'. WI doesn't require pole cars until you get past 16' generally.
    There are signs before all of the HWY 100 exits warning oversize of restrictions within the county once they pass HWY 100. The only one I know of that warns for height is on I-43 NB just before the Layton Ave exit coming out of Waukesha County. There is a 14'2" bridge past that with no other options to get off before it.
    If he was 15'+ though he couldn't use the HWY 100 bypass route because there is a 14'3" bridge that crosses it in Hales Corners.
    There are no signs warning about height coming from the south up I-94 from Chicago because there are a lot of Industrial places in the southern part of the county that are inside the HWY 100 loop that are easily accessible from the Interstate at 16' high.
    All those bridges down there have been replaced in the last 15 or so years as they have been widening I-94 so most of them are 16-17' High.
    If he had bothered to get a permit he would've been kept way west of the city and probably run up through Waukesha county at that kind of height.
  11. JonJon78
    7,042
    37,578
    Jul 1, 2018
    Not sure?
    D.Tibbitt, PoleCrusher, cke and 2 others Thank this.
