Oversize question....Rear overhang permissable on this load? (PA, NY)
Discussion in 'Heavy Haul Trucking Forum' started by rank, Jan 26, 2013.
  1. rank
    rank Road Train Member
    9,919
    113,507
    Feb 11, 2010
    According to everything I've been able to read on the NYDOT and PennDOT websites, this should be legal. Do you agree, and if not, why not?
    (4) pcs loaded end to end on a 53' trailer + a 5th piece (sitting on top of the 4th piece) that is ~15' long and hangs out the back ~18".
    PA Route is: 41, 30, I-283, I-83, I-81, 22, 11, 147, 180, 15 to NY
    NY Route is: 15, I-86, I-390, 20, 63, 77, 31, 1-190 to ON
    Trailer length: 53'
    Overall length including load: 76'
    Rear Overhang: 18"
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    http://www.search.cio.ny.gov/search?q=overhang&btnG=&client=dot_frontend&output=xml_no_dtd&proxystylesheet=dot_frontend&proxycustom=&sort=date%3AD%3AL%3Ad1&entqr=0&oe=UTF-8&ie=UTF-8&ud=1&site=dot_collectionPERM 87 (11/03 version) second from the bottom
    [FONT=TimesNewRoman,Bold]STATE OF NEW YORK[/FONT]
    DEPARTMENT OF TRANSPORTATION
    [/FONT][FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]CENTRAL PERMIT OFFICE
    50 Wolf Road, 1st Floor, Albany, New York 12232
    [/FONT]
    [/FONT][FONT=TimesNewRoman,Bold]GUIDELINES FOR SPECIAL HAULING PERMIT REQUIREMENTS
    [/FONT]
    [FONT=TimesNewRoman,Bold][/FONT](Special Requirements indicated on permit issued may be different than guidelines below based on engineering judgement, weights, and specific highway geometry)
    [FONT=TimesNewRoman,Bold]OVERHANG REQUIREMENTS
    [/FONT]
    [FONT=TimesNewRoman,Bold][/FONT]4'-0" OR GREATER - 18" x 18" RED OR ORANGE FLOURESCENT FLAGS ON STAFF ON END OF LOAD
    - TWO FLAGS REQUIRED ON STAFFS AT THE EXTREMITIES OF THE OVERHANG IF WIDTH OF
    OVERHANG IS MORE THAN 2 FEET
    GREATER THAN 10'-0" - CERTIFIED ESCORT VEHICLE TO FOLLOW WHEN REAR OVERHANG IS GREATER THAN
  4. rank
    9,919
    113,507
    Feb 11, 2010
    Exactly the document that I have in my little rule book. So it's a legal load, no permit required right? Now for the rest of the story.
    The 4 pieces loaded end to end were 10'-2" wide and they would not give me a permit because "the 5th piece is illegal because you are creating a dimension." I said yeah but it's a legal dimension. Had to take the 5th piece off get to zero rear overhang to get the permit for width.
    Can anyone show me the rule for that because I cannot find it.
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    You have a 53' trailer....already the longest trailer allowed under the law...and even that is strictly limited to specific routes. An 18" overhang on the rear would make the trailer & load 54.5' in length.
    https://www.dot.ny.gov/nypermits/repository/perm71b.pdf
    If you can remove part of the load to prevent adding that extra length, you can't get a permit for the extra length...just like you wouldn't be able to get an overwidth permit to place a pair of 5' wide objects side by side on the trailer.
  6. rank
    9,919
    113,507
    Feb 11, 2010
    In your opinion, would the load in my OP be legal or illegal on the national network?
  7. ralph
    1,112
    632
    Mar 1, 2009
    At The Key Board
    That apparently is very controversial. I run around LOTS with 2' hanging out the front of my 53' wagon and am yet to be bothered. I know it is somewhat argumentative as to whether it's legal or not>each jurisdiction deals with it differently.
    Pennsylvania Oversize Load / Pilot Car Requirements[HR][/HR]Oversize and Overweight Loads and Vehicles
    [TABLE="width: 100%"]
    [TR]
    [TD="width: 50%"]Oversize Load Permit Is Required:
    Width: Over 8' 0" (8' 6" on numbered routes, unless posted)
    Height: Over 13' 6"
    Length: Semi-trailer over 53' 0"
    Weight: Over 80,000 lbs. GVW (20,000 lbs. single axle or 34,000 lbs. tandem axle)
    [/TD]
    [/TR]
    [/TABLE]
  8. rank
    9,919
    113,507
    Feb 11, 2010
    I hear you. I run around LOTS with 3' hanging out the BACK of my 53's without a permit and have never been bothered for rear overhang. Seems perfectly legal to me based on the rule you posted above and the NYDOT seem to agree.
    Which brings me back to my question above.....if, presumably I am legal with 3' hanging out the back of a 53 when I am 102" wide, why am I not legal when I am over width?
  9. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Because it is now a divisible load. I have NY overweight and over width permits. It goes like this; you have an item that is over width and you want to add a separate item that is over length. They see that a two special hauls. Remember NY is ALL about the money. This way they can get two permits out of you instead of one. I know this is an old thread, just wanted to add to the knowledge base here.
    aiwiron Thanks this.
  10. rank
    9,919
    113,507
    Feb 11, 2010
    Well that's the only answer that makes sense to me. Thanks.
    cetanediesel Thanks this.
  11. hagarcobra
    hagarcobra Medium Load Member
    334
    747
    May 24, 2013
    your question makes no sense at all.if you are overwidth,then you are by definition not legal.length is irrelevant.
